Epoxy coating.....cloth, color????
Ok! here is the start of the questions. I know that some are using a method of applying epoxy and fiberglass resin to strenthen the exterior and then have a base for painting. My question is, this is applied in several coats, and seems to give a translucent appearance. Can you apply a colored cloth one or two coats under the surface to give the outside of the camper its color. Say I wanted a flower pattern to the out side could I apply the resin, fiberglass, resin, resin, cloth, resin, resin and use the last cloth to give the outside its color? Say I wanted it camofloged. Or would it be better to do the outside then apply the camo vynl material to the outside.
I like the silver outside but I can see that it would require a lot of work to maintain it. I like no work my self.
