by Alphacarina » Sat Sep 27, 2008 4:42 pm
Taking out a spring leaf will help a little - Better would be a switch to 13 or 14 inch tires which you could run only 25 or 30 pounds in. Running less than the rated pressure (60PSI?) in the little HF 8 and 12 inch wheels is risky . . . . they want those tires rock hard so that they don't build up any heat whereas an automotive tire will do just fine at 25 pounds . . . . probably even as low as 20 pounds on a less than 1,000 pound trailer - THAT would eliminate your bounce 100%
Don
