Varnishing Question?
Postby Classic Finn » Mon Sep 29, 2008 8:15 am
Im doing some varnishing here on shelf and cabinetry in the tear and using Marine Varnish. How many coats have you applied ?
I know its also a matter of perference to each builder but in general how many coats is enough as not to over do it?
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Re: Varnishing Question?
Postby Miriam C. » Mon Sep 29, 2008 9:25 am
Classic Finn wrote:Im doing some varnishing here on shelf and cabinetry in the tear and using Marine Varnish. How many coats have you applied ?
Classic Finn ;)
At least 4 and I think more unless you are redoing it every year. You might ask the guy with the boat. I bet he can tell you what you need for your area. :thumbsup:
Postby Classic Finn » Mon Sep 29, 2008 9:28 am
Classic Finn ;)
Hi Aunti M :)
He has 8 -10 coats. With fine sandpaper sanding in between coats. I talked with him an hour or so ago. I have half gloss
varnish. The more the shinier I guess. I dont want to do it every year on the inside.
So I dont need it as glossy as he has it. Ok well 2 coats on so far but I,ll do a couple more. ;)
Classic Finn
Images: 146
Postby SkipperSue » Mon Sep 29, 2008 10:11 am
Heya Hekki,
I put like 10 coats on my main shelf. I light sanded with a 600 grit paper between each coat using my palm sander. Made it look really smooth and even. Like Miriam, I put 4 coats on everything else back there in the galley area but with no sanding.
Skipper
SkipperSue
Images: 114
Postby Classic Finn » Mon Sep 29, 2008 1:38 pm
SkipperSue wrote:Heya Hekki,
Howdy Skipper..
10 coats..okidoki. more the shinier :) 8) :thumbsup:
Classic Finn
Images: 146
