Page 1 of 2
Clear coat...painting issues...errrrg
Posted:
Sat Oct 04, 2008 6:17 pm
by Juneaudave
Life is a journey and one of the things I've wanted to do is learn how to paint with a HPLV. Fenders turned out well...but the doggone hatch has issues with clear coat...
On the first coat..I sprayed too dry...not enough paint and too much air...
Next coat...too much paint and too little air...eerrrg sags...
And on it goes (hats off to the guys who really know how to do this)...
You can see the orange peel and sags...what's my next step...
Sand and recoat or buff and polish???
Posted:
Sat Oct 04, 2008 7:58 pm
by Mary K
I dont know what to tall ya, but it look beautiful to me anyway.
Mk
Posted:
Sat Oct 04, 2008 8:34 pm
by madjack
JD, the only way to get rid of the sags and orange peel is to sand and repaint...all I can say is damnitman and practice, practice, practice......
Posted:
Sat Oct 04, 2008 10:35 pm
by Boodro
JD , orange peel can be buffed out with some aggressive rubbing compound & a good random orbit polisher. My son's car had it when we repainted it & he spent the time do some wet sanding then buff it with compound , then polished it with a polishing compound after he had it smooth. The sags will have to be sanded out then maybe touched up with another clear coat. Good luck!
Posted:
Sun Oct 05, 2008 12:16 am
by cuyeda
What they said... wetsand... Like you, I need some practice shooting, but watching my dad paint a few cars in the day, I learned the sanding part. ha ha. I used a wet sand paper, and a small thin rubber block squigee (sp) as a backer. After wet sanding an area down, I then used the rubber squigee to pull the water away from the surface. A quick look across the surface will reveal any imperfections. Repeat as necessary, then polish.
Good luck!
Don't cut cornrs now!
Posted:
Sun Oct 05, 2008 1:11 am
by RICHARD FURROW
I agree. It would not hurt to be lightly sanding between coats anyway. It would be less apt to run, and you can build up more protection and gloss. You have one beautiful Teardrop, and this is just a minor setback. Don't accept nothing but the perfection you have been striving for. Don't cut any corners now. You have been very inspirational to me. I've truly enjoyed your build.
Ricky
Posted:
Sun Oct 05, 2008 9:45 am
by Juneaudave
A sanding we will go
Hi ho the merry oh
Posted:
Sun Oct 05, 2008 12:28 pm
by doug hodder
Dave...the sanding is a lot easier if you do it in the first 72 hours or so. After that, it becomes much more difficult. For me, usually the first coat is only a tack coat. Just get some material on to cover it, don't worry about orange peel or gloss, let it flash off a bit, then put on the next couple of coats, letting it flash off in between, just a couple of minutes. The next coats will melt into the first ones. I think a person is better off trying to do several coats of lighter sprays than a heavier one.
Don't be hard on yourself...you gotta learn and this is only the 2nd thing you've painted isn't it? I painted a lot of beasts before I got a beauty! I still paint a lot of beasts...
Doug
Posted:
Sun Oct 05, 2008 4:12 pm
by Juneaudave
doug hodder wrote:Dave...the sanding is a lot easier if you do it in the first 72 hours or so. After that, it becomes much more difficult. For me, usually the first coat is only a tack coat. Just get some material on to cover it, don't worry about orange peel or gloss, let it flash off a bit, then put on the next couple of coats, letting it flash off in between, just a couple of minutes. The next coats will melt into the first ones. I think a person is better off trying to do several coats of lighter sprays than a heavier one.
Doug
I'm on it and yea...so far, I've painted a burn barrel and a set of fenders!!! That clear is hard stuff to sand (even at 24 hours) but I have pretty much got it down to 600 grit so far. Even at 600, it looks alot better. I think my mistake was too dry on the first coat and I never recovered being a "painter want to be". I'm optomistic that I'm going to be ok on my next try. We'll see!!! If this don't work, I'm flying you up, or moving to spar varnish!!!!
Posted:
Sun Oct 05, 2008 5:46 pm
by doug hodder
Dave...unfortunately (in my opinion) a mistake that some new painters make is to pile on more paint and make it smoother, trying to get the perfect coat in 1 shot, get a good gloss then blupppp...it sags or runs...next thing you're doing is mopping it off the floor. I haven't had any "official" instruction or education on it all, just what I've found as I went along. If you haven't dragged the hose through it, you're still ahead of the game!
I don't think you'd need to go to 600 on the sags. The clear can cover a 320 scratch. It might be wise to contact your paint supplier and check with them to see how long it needs to cure prior to a recoat. If done early, you can just spray...if it goes too long, it needs to have an entire scuff on it, then shoot it. At least that's what they tell me on the Transtar Euroclear. Others opinions may differ. Doug
Posted:
Sun Oct 05, 2008 5:55 pm
by Juneaudave
Well, try number 2 went better than try number 1...then I ran out of clear!!!!
No sags...but a bit dry...I'm a thinking it is close enough for rubbing compund, polishing compound and of course...wax on..wax off...grasshopper!!!! Shucks...by the time I get this done... Earl Schieb is going to be looking good!!! It has been entertaining though!!!
Posted:
Sun Oct 05, 2008 6:04 pm
by doug hodder
Posted:
Sun Oct 05, 2008 6:09 pm
by doug hodder
PS, if you decide to do a polish on it...I'd mask off the vertical edges of the "straps" running full length, before you hit it with a polisher. It'll save you from burning through those areas. Doug
Posted:
Sun Oct 05, 2008 6:15 pm
by del
Posted:
Sun Oct 05, 2008 7:49 pm
by hiker chick
Gorgeous!!
