What's the best exterior caulk material?
Postby duke » Sun Oct 05, 2008 9:09 pm
I need to install some aluminum side table brackets on my tear. What's the best material to bed them in to protect the screw holes? Silicone, poly, etc?
:thinking:
There comes a time in every rightly constructed boy's life that he has a raging desire to go somewhere and dig for hidden treasure. - Mark Twain
Image.Image
duke
Images: 7
Postby Boodro » Sun Oct 05, 2008 10:33 pm
Duke , I use silicone it seems to hold up well. Just don't be to chinzy with it. 8) Use plenty , then wipe away the excess. Good luck! :thumbsup: :thumbsup:
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby looped » Mon Oct 06, 2008 12:35 am
i used silicone I from ge i believe (bought at home depot) to go under my trim. if you plan to paint over it then i believe silicone II would work for it. whatever you get, really gob it on there,, better to have too much and not need it than to have not enough and do.
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby Rickxr2 » Mon Oct 06, 2008 6:51 am
I',m a poly man myself. Silicone may stay flexible forever, but I've seen the bond break down way too often.
xr2
Image Image Image
Rickxr2
Images: 125
Postby Hoosier Greg » Mon Oct 06, 2008 7:17 am
I'm in the door and window business. My choice in Caulk is Nova flex or Boss..
Both can be found at any Real building supply House...
GE is another I would use when in a pinch. I don't like it as well as the other two because it is too runny.
The trick is in making sure the surface is clean before you apply the caulk.If not, it will pull away from the surface due to expansion and contraction and for no other reason.....
Greg.
Hoosier Greg
