Outside epoxy with UV color stability
Belco Company Claim on Superior Urethane Top Coat:
[i]Excellent Flexibility, UV Color Stability, Weathering Characteristics Superior Urethane Top Coat is a two component, catalyzed aliphatic polyester polyurethane floor sealer with unparalleled resistance to abrasion, chemicals and impact. Superior Urethane Top Coat may be used indoors or out to provide a smooth glossy floor with the best protective properties available. They are ideal finishes over epoxy.[/i]
Has anyone tried this stuff? It comes in clear and colors. It can be used outside and has UV color stability. I'm a little concerned about the UV color stability claim. Could the possibly fail due to UV rays, but still have good color stability?
Sounds good, just wondering if it has had the ultimate Teardrop Testing? A little pricey, but could be worth it.
http://www.belcosupply.com/shop/pc/view ... tegory=974
Ricky
Ricky
