by doug hodder » Tue Mar 22, 2005 10:53 pm
Make sure to use a sharp carbide blade, also I raise the blade up quite a bit. This changes the angle of attack of the blade and is less likely to kick back, but instead down onto the saw deck. Don't crowd it, wear a face shield. Clamp the material to your slide mechanism. Especially on angles. Once it hangs and you are trying to hold it by hand you'll remember. I also use gloves. I've cut lots of 1/8" aluminum sheets using a guide and a circular saw also. Again, use a carbide blade, and in thick material, make sure you use some sort of lubricant, ideally a cutting spray fluid, WD 40 will do in a pinch, and if you want to hear in the future, some sort of hearing protection. I've ripped 10'sheets of 1/8" aluminum this way. It takes a good saw however, as an underpowered one with a bad arbor will cause you fits. Experiment. PS I have a bunch of throat plates for the table saw. I made them out of 1/4" paneling. Put one in and crank the blade up through it to the height you want. Excessive gap at the blade can make things interesting really fast!!! Doug Hodder
