Is 67 inches too wide for a Teardrop?
Postby wantaTD » Mon Dec 01, 2008 7:03 am
I have available a old travel trailer frame. Its 67 inches wide and 243 inches long with tandem axles. If I drop the 2nd axle. Make the front spring perch the rear one. The 40% ratio is real close. Any thoughts?
wantaTD
Postby GPW » Mon Dec 01, 2008 8:02 am
If you're Large like us , you might want it a little bigger/wider... :thumbsup:
Postby madjack » Mon Dec 01, 2008 11:12 am
...too wide???...NAW..but keep in mind that any width over 80"(including) will require additional lighting...this width includes lights, bolt heads or any other protrusions...not a biggie but needs to be in mind while building...243" long...that is about 6' too long...unless you are building a monster..........
Postby bobhenry » Mon Dec 01, 2008 11:55 am
Mine is 5' 7" out to out but wheels are under. It is a nice size at 5'4" inside.
I am 300 plus and wife is "well endowed too (did I mention she was a good cook) so go for it. You might concider leaving the dual axle set up there are several on this forum. The ride is much better and you can limp home on a flat if needed. You might incorporate a little of the extra frame length for a tongue box but mount it on the frame in front of the tear body then bob the tail of the frame. Draw it out to scale you may suprise yourself how good it can look.
Postby GregB » Mon Dec 01, 2008 2:57 pm
Mine is 66" wide but only 156" long with 60" tall walls. The wall height seems to affect the look more than the width.
GB
I'm not dead, yet. I'm feeling better.
GregB
Images: 108
Postby Jst83 » Mon Dec 01, 2008 5:09 pm
Mine is 6'6" x11'6" 78"x138"
I think 67" x 243" would look pretty narrow
Jst83
Images: 215
Postby mikeschn » Mon Dec 01, 2008 6:08 pm
Not at all. My Winter Warrior/Escape Hatch was 66" wide, and it was perfect.
When I finally build my optimized Winter Warrior, it'll be 68" wide (the width of our Forester).
Thanks for the feedback
Postby wantaTD » Mon Dec 01, 2008 6:41 pm
My plan so far is to leave the 80 inch wheel base. With 67 inch wide sidewalls. Shorten the frame to 164 inches. Ball to bumper. I want a bumper. Design my cabin on a 10ft platform. Queen size bed. I was going to eliminate the second axle. :twisted: Anyone have a picture of a teardrop with dual axle. Time to put this on paper.
wantaTD
Postby mikeschn » Mon Dec 01, 2008 6:55 pm
How about this one?
or this one
or this one
Re: Thanks for the feedback
Postby brian_bp » Mon Dec 01, 2008 8:13 pm
wantaTD wrote:My plan so far is to leave the 80 inch wheel base. With 67 inch wide sidewalls...
By this, do you mean an 80" track width, or perhaps 80" between hub faces (the same thing as track width if the wheels have zero offset), or maybe 80" overall width across the tires?
Wheelbase is from front axle to rear (doesn't apply to conventional trailers), and track width is between the tire centres... lots of people seem to confuse the two.
At 80" of track the trailer would be clearly over 80" wide, triggering the lighting requirements which madjack mentioned.
brian_bp
Images: 9
Postby jdarkoregon » Tue Dec 02, 2008 1:58 am
WantaTD
What are you pulling it with? You'll want to be able to see whats behind you when you are pulliing it down the road.
Good question, but if you are going to build it, Design it and build it for yourself, Wide or narrow, you'll love it.
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby bobhenry » Tue Dec 02, 2008 7:25 am
jdarkoregon wrote:WantaTD
John
John's is the first one that came to my mind ain't it sharp lookin'
If you have never pulled a dual axle trailer by all means borrow one the try it out. The bouncing and ball rattling jumping up and down are all but gone they pull real well.
Maybe I otta start on my 8' x 26' foot flatbed it has duals :thinking:
Postby GPW » Tue Dec 02, 2008 7:48 am
Our first TD ...6'X12" was on a standard boat trailer , then we got a dually TT... Tows really nice , Trailer seems more stable just sitting too... looking for a four wheeled boat trailer for our next standy/hammy project...6'X10' Wide is Good... and comfortable ...
Bobhenry... 300+??? ... and I thought I was Old ... :roll: :lol:
"Ooops" My Track is 80 inches
Postby wantaTD » Sun Dec 21, 2008 5:55 pm
My track is 80 inches (measured from outside of the tires) The track on my tow vehicle is 70 inches. (2006 Hyundai Santa Fe) At 67 inches I can still see down the sides without elaborate mirror system. I have no problem lighting it up like a Christmas tree for DMV. The Tamden axles are still on the design table. It would sure help the tongue weight.
wantaTD
Postby Roly Nelson » Sun Dec 21, 2008 8:19 pm
Wow, 80 inches wide. All I can say is that you will be twice a happy as I am with my 40 wide 1/4 Nelson Stacker teardrop.
:) Roly
Roly Nelson
L'il Ol' Woody Builder
