by mikeschn » Tue Mar 29, 2005 8:09 am
Vinyl is not designed for exterior use. It will probably yellow, and crack with exposure to the elements.
Then you are better off covering it with PVC like Bev did, or TPO like Chip did.
I like Uniflex255 for a number of reasons...
I don't need to buy contact cement, and rollers to apply it with.
I don't need to buy edge molding, inserts, screws and caulking
You can probably cover a 4x8 teardrop with 1 gallon of Uniflex 255.
If you make a design change, it's easy to touch up the affected area
Ditto if you get some road damage
You can refresh it with a new coat of paint if it starts looking bad
It has UV inhibitors in it, so it can handle the weather!
It's white, which keeps the teardrop much cooler during the day
It has a nice textured surface
It hides minor imperfections in the wood.
With the money you save on contact cement, corner molding, screws, caulking and labor, you can buy a better paint, roll it on and be done with it.
P.S. I don't know the cost per sq ft. You'd have to ask Dr. Rot.
mikeschn on Tue Mar 29, 2005 8:17 am, edited 1 time in total.
