Does anyone have plans for a 5'x 9' cubby
Postby DustinMoore » Mon Jan 12, 2009 8:03 pm
I was contemplating building on a 5'x8' redtrailer but found a steal on a sturdier 5'x9'. After consideration I realized the walls may be more difficult to construct since a 4x8 piece of plywood won't work.
Does anyone have any ideas or plans for a 5' x 9' platform?
Your help is greatly appreciated
DustinMoore
Postby 01Sport » Tue Jan 13, 2009 12:37 pm
Build a 1' box on the front for extra storage? :thinking:
K.C.
Teardrop Name: Golden State Teardrop
01Sport
Images: 29
Postby toypusher » Tue Jan 13, 2009 12:53 pm
You can adapt most any profile to that. If you want a cubby style you can just add a foot to the center where it it flat. If you are putting aluminum on the outside, then just splice the extra length on with more plywood.
toypusher
Images: 324
Postby bobhenry » Tue Jan 13, 2009 12:54 pm
I'm 5 1/2' x 5 1/2 ' x 10'
this picture will help !
If you look thru this picture to the house side you will see a 1x4 has been used to splice the sheets at the door edge. This minimizes the length of the splice to just above and below the door the rear splice is at the galley wall. Cruise thru the album 13 14 15 16 you will get the idea. I later guled the luan exterior on using 2x4's on edge and clamps. I off set the veneer luan to the front of the door to stager the joints.
Postby reiltear » Tue Jan 13, 2009 9:34 pm
Dustin, welcome to the forum!
There is another alternative to building your teardrop. You can use these plans as a guideline for building it and shorten the flat part of this profile by 7-1/2"(60" stays the same, 72" becomes 64-1/2", 84" becomes 76-1/2", etc., the vertical dimensions stay the same).
If you have any questions, don't hesitate to ask, that's what the forum is here for.
Hope this helps.
reiltear
Images: 18
Postby DustinMoore » Tue Jan 13, 2009 11:17 pm
Thank you all for your suggestions. Are there any lumber distributors you would recommend for oversized plywood that are reasonably priced?
I found a trailer and I'm excited to begin with the floor and sides. Also, the designs and photos are greatly appreciated.
Thank you, Dustin[/b]
DustinMoore
Postby madjack » Tue Jan 13, 2009 11:58 pm
...reasonably priced, oversized ply does not exist...use a scarf joint, a biscuit jioner or the slot and spline method to make your own...any good waterproof wood adhesive will work but epoxy is what I prefer............
p.s. here is a current thread on the subject... http://tnttt.com/viewtopic.php?t=27570
Postby DustinMoore » Thu Jan 15, 2009 6:52 am
Bob Henry,
Thank you for the advice. Would it be possiblw for you to repost the link with you album... For some reason its not actve.
Thanks, Dustin
DustinMoore
Postby bobhenry » Thu Jan 15, 2009 7:01 am
Dustin just scroll up to my post above and click on the red "ALBUM" button. Most of Chubby's build pics are pages 13 14 15 in the album
Postby mikeschn » Thu Jan 15, 2009 7:43 am
DustinMoore wrote:Bob Henry,
Thanks, Dustin
Dustin,
I think it's only fair to note here that OSB is not a very good material for building.
If you do a search on OSB, up there in the menu, you'll read some very negative comments on that for a building material.
Postby bobhenry » Thu Jan 15, 2009 3:57 pm
ouch !
I didn't plan on being poor it just worked out that way !
Postby mikeschn » Fri Jan 16, 2009 9:15 pm
Sorry Bob,
I wasn't picking on you, just the OSB.
BTW, someone has a question on plexiglass here...
http://tnttt.com/viewto ... highlight=
Postby bobhenry » Sat Jan 17, 2009 6:23 am
Looks like he solved his problem with a real good score on windows and doors.
Thank you again for all of your suggestions
Postby DustinMoore » Wed Jan 28, 2009 6:44 am
I am located in Monterey, CA and ideally I would like to purchase the sides pre-cut. I am working on a 5' x 9' frame and was wondeinng if anyone knows of a supplier in California with 5' x 10' exterior grade plywood that will cut out-the pattern of my choice?
I know its alot to ask but with my limited working space I believe this may be my best option.
Your suggestions are greatly appreciated!
Dustin
DustinMoore
Postby grant whipp » Wed Jan 28, 2009 11:48 am
Dustin ...
... I'm in Redding (about 5-6 hours north of you, depending on which route you take) ... I've provided that service before. Drop me an e-mail at [email protected] ... or give me a call this evening ...
www.LilBear.teardrops.net
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
