tinksdad wrote:A few years back, I had a 23' Yellowstone that was 20+ years of age when I bought it. At one time or another while I owned it it, I replaced several of the propane appliances and had to run new copper feed lines as well. It's a personal choice; but I don't like compression fittings. Using a flaring tool is not that complicated, just takes common sense. My only suggestion, if you choose to run copper lines, is wherever the line passes through the floor, frame rail or bulkhead, if you don't use some type of fitting, definitely insulate from vibration with some type of rubber grommet.
Esteban wrote:I went by Home Depot in San Luis Obispo, CA yesterday. They had coils of copper pipe in 1/2", 3/8" and 1/4" sizes. There were no fittings for the 3/8" or 1/4" pipe. Where would you get the fittings for hooking up the smaller sized pipe?
In the future I'd like to have a LP tank on the tongue and a gas line running from it to the galley to supply a Camp Chef Camp Oven. My trailer frame has 2" x 2" L angle cross supports that I've drilled 3/4" holes through to run a gas line. Bought nylon grommets from DelCity.net to fit in the holes to support and protect the (future) gas line.
Would appreciate seeing photos, or plans, about how to do this. Something similar to the electrical plans in Electrical Secrets.
