axles and wheels
axles and wheels
Postby arcadiainc » Wed Mar 30, 2005 2:12 pm
Am in the final stages of planning. Going to go all out and build a five by ten with a/c etc. My question is I want to use 225-75 x 15
tires mounted on Jeep Cherokee wheels. This way I will not need to carry an extra spare tire. I need a source of supply on an axle, torsion or spring, that will allow me to use my desired tire wheel combo. Ideas anyone? Thank you in advance
arcadiainc
Postby asianflava » Wed Mar 30, 2005 2:55 pm
What is the bolt pattern for the Jeep wheels? The trailers axle hubs are typically 5X4.5. If your wheels aren't this size, I'd forget about it. Otherwise you can check a local trailer place or, e trailer Northern Tool.
asianflava
Postby SteveH » Wed Mar 30, 2005 3:29 pm
arcadiainc,
First, welcome to the forum.
I just completed a 5'wide tear using a torque type axel from Southwest Wheel in Lubbock, Tx. I'm also using 15 X 7" jeep wheels with 205-75 X15 tires. Not quite as big on the tires, but close. I have about an inch clearance between the tires and the sides of the tear.
There are pictures in my gallery if you want to take a look.
SteveH
SteveH
Images: 42
Postby smithder01 » Wed Mar 30, 2005 6:47 pm
the jeep wheels are 5 x 4.5
smithder01
