kennyrayandersen wrote:...
10" tires (how much heavier than 8" tires?)...
Alloy wheels?...
brian_bp wrote:angib wrote:...
The fiberglass-faced aluminium-honeycomb core panels they used won't be cheap, but the cost of this sort of thing is reducing all the time.
Andrew
That's fascinating stuff, and the end result looks good, but the technique has a worst-of-both-worlds flavour to me. The honeycomb-cored sandwich is fine and relieves the outer body of any structural requirement, but the foam and 'glass over top is the nightmare of massive finishing effort which Andrew has mentioned before - all the work and none of the benefit of other techniques. The foam isn't a structural problem, but it's also not a structural benefit.
To use these panels in a trailer, it would make sense if they could be the final shape themselves, and not need and envelope of foam-and-'glass around them. I don't know how you would get the desired teardrop curve with these inherently flat panels; they seem limited to internal structures or "origami" styling (which I don't mind, but is not classic teardrop).
As for the car project... if stealth aircraft can be built with nothing but flat surfaces and work aerodynamically, perhaps a car can be, too. Skip the whole carved-foam and fiberglass covering stage!
kennyrayandersen wrote:I wasn't going to use a steel frame but a 2"X2" square pine/fir perimeter frame buried into the floor panel with a 1"X2" cross member at the rear wall and that was about it.
kennyrayandersen wrote:MK10108
I think you're tight it would be very difficult to get all of the epoxy, or perhaps a polyester resin down all of the holes. Additionally, it's actually not that light once they're all filled up. I'm pretty sold on the foam core with the glass facesheets -- I'm not seeing anything short of NOMEX and graphite that would be any lighter, and the graphite/NOMEX comb would be prohibitively expense. In fact it's light enough and strong enough that I think I'm using is for all of the shelves as well.
kennyrayandersen wrote:... I was thinking more like the 145/80R10 which at 10 Lb is available through Tire Rack with maybe a Minilite wheel, but even that alloy one weighs10 Lb.; even that’s not any lighter than the 12 in trailer wheels and tires...
kennyrayandersen wrote:... ...(your observation that the alloy wheels aren’t any lighter seems to be pretty true – there’s always magnesium!$)...
Arne wrote:One thing about a full torsion axle, it is far heavier than I expected. I'm guessing around 70-80 pounds.
kennyrayandersen wrote:So, first decision tires and rims – 8 inch – just too big of a weight penalty for the 10s or 12s.
