Basic woodworking question...
Postby Shrug53 » Sun Apr 03, 2005 10:11 am
If I join two pieces of plywood usings biscuits, do the just glue together? Do I use finishing nails or something? Just biscuits and glue does not seem like it would be enough.
Also If I want recessed screws, so that I can use plugs to cover them. Is there a special drillbit for that?
Many thanks!
"Better living through reckless experimentation"
http://www.forgottenclassics.com
Shrug53
Postby norm perkiss » Sun Apr 03, 2005 10:58 am
Shrug,
I'm not a woodworking expert, but here's my 2ยข.
I've used the biscuit method a couple of times. Most of the glues available today create a bond that is stronger than the wood. The biscuits add strength and provide alignment of the joining surfaces. For cabinets and such, the biscuit method is plenty strong.
I use a "forsner bit" (may have spelled it wrong) for plugging. I start using the forsner bit, drilling deep enough the accept the screw head and the plug. Then switch to a regular bit and continue drilling to complete the pilot hole. There may be other methods, but it's worked for me.
Norm
norm perkiss
Images: 62
Postby toypusher » Sun Apr 03, 2005 11:07 am
Shrug,
Try looking at this link: http://www.rockler.com/ecom7/product_details.cfm?offerings_id=10607
You can get these at most home improvement or woodworking stores.
I have used biscuits for my projects for years. The typical joint is very strong and can withstand quite a bit, however, I would need to know where the joint is being put in your aplication to give you a better feel for the strength. If is is used to extend your sidewall on a teardrop and is supported with vertical bracing and and interior wall, I belive that is should be fine. You may want to use polyurethene glue (i.e., Gorilla Glue).
Just my opinion, but hope it helps.
Kerry
toypusher
Images: 324
Postby Shrug53 » Sun Apr 03, 2005 11:09 am
Thanks for the info. Yeah the join will be for sidewalls. 4x8 is just not big enough. I would like my sidewalls to be 5x10 but that seems an almost impossible size to find. When you do, it costs a heck of a lot more.
Shrug53
Postby BrianB » Sun Apr 03, 2005 11:46 am
For countersinking screws, I've always just used a small bit for the pilot hole and then following that up with a drill bit the size of the screw head that only goes a little ways into the wood.
A little more work, but that's a good way to do it if you don't want to go out and buy more tools.
BrianB
Postby Shrug53 » Sun Apr 03, 2005 11:53 am
If I don't want to buy more tools? I don't understand. I know the words are english, but they make no sense in that configuration :lol:
Shrug53
Biscuits and drills
Postby TWO-CANS » Sun Apr 03, 2005 1:04 pm
Biscuits are meant to align your pieces of wood and when used properly, glueing the edge and into the biscuit cut, the biscuits expand and strengthen/secure the joint. Use the right size biscuit to fit your cut, I would, should I glue ply in this manner, not depend on the glue and biscuits alone but have a backer/ support built into the frame at this joint. Glueing with biscuits or scarving can not give the needed strength alone when used on plywood a multi layed edge. Biscuts and glued edges work fine on solid wood in the proper application.
There is a combination drill countersink in any decent tool section of Lowe's Home Depot etc. One hole one for the screw as a pilot and the second wider hole for the plug. Buy a plug cutter also and your plugs cut from scrap amtch the wood your plugging.
TWO-CANS
Postby BrianB » Sun Apr 03, 2005 1:37 pm
Shrug53 wrote:If I don't want to buy more tools? I don't understand. I know the words are english, but they make no sense in that configuration :lol:
You're not the only one. I started to twitch while writing that. :lol:
BrianB
Joint
Postby An Ol Timer » Sun Apr 03, 2005 2:16 pm
I have made many scarfed joints, and when made properly, and the right adhesive is used and cured out properly, you can't beat the joint for strength or looks. Just a boatbuilder's opinion
An Ol Timer
Postby doug hodder » Sun Apr 03, 2005 7:48 pm
I agree with Ol timer's opinion. A scarf joint is going to give you excellent strength. I'm a boat builder too. I think that for the average woodworker, it might be a little bit of a challenge for a joint that may be 4 feet long. I look at it this way. If it isn't going to be seen and is going to be covered with either aluminum or a laminate, I go with using a 3 wing cutter in the router. It cuts a groove 1/2 inch deep into each of the pieces. I then cut a spline in a good hardwood, and glue it up using epoxy. (butt joint with a spline).. It's like adding 10 times the biscuits depending on how you space them. It works for me as I overlayed the plywood with 6mil mohogany on the exterior and birch on the interior. I stretched my 4x8's into 4x10's and they are plenty strong. For me, I always have a tough time scarfing veneered plywood so that the grain matches up really well without sanding into the core. I'm still learning though. Doug Hodder
Postby Boodro » Sun Apr 03, 2005 8:25 pm
Hey Shrug, I extended my wall to 12 ft . Where the 8 ft met the 4ft section I installd a 1x2 poplar on the seam , glued & screwed all the way down the seam ,stagering the screws from side to side . After the glue was cured I filled in any voids with Elmers wood paste along with the counter sunk screws then sanded . You can only tell there was a seam there because of the filler. Other wise it seems to very strong. Have fun! 8)
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby len19070 » Fri Apr 08, 2005 12:19 am
I had to build some 5X12' plywood for a project and I didn't think just a bisket & glue was strong enough either (though many experts said it was). So what I did was Rout a 1/8" slot in 1/2" Laun plywood, glue in an 1/8" spline to join the 2 pieces. Then laminate 1/8" Laun to each side, staggering all joints. 5X12X3/4 Laun...The Hard Way.
Happy Trails,
Len
len19070
Images: 24
Postby shil » Fri Apr 08, 2005 12:06 pm
My trailer's about 10' long, so a 4 x 8 wouldn't cut it. I built the sides from solid 3/4" ply, butt jointed together with wood glue and dowels. I already had a doweling jig and didn't want to buy more tools. Shrug, you're right: those words make no sense.
Anyhow, once the glue set the joint was strong enough that we could easily pick the piece up and move it around, no worries. I positioned the joint right at the galley wall and backed it up with a butt block, with a dado for that wall ploughed into the block. If I hadn't used a dado I would not have bothered backing up the joint.
Scarf joints are swell for boats, where you may be bending the plywood into a boat like shape, there's no 'hard spot' caused by the butt block. IMHO it's overkill for a straight, flat wall. Like Norm said, glues today are stronger than wood.
What a great long post. Bored at work today...
shil
