TheOtherSean wrote:Hello, fellow trailer enthusiasts! I'm looking for some advice.
I'm working on plans for a tiny travel trailer with a projected dry weight less than 1400lb. Given full tanks and loaded with food, clothes, etc. , it should still be well under 2000lb, but once a few people are inside, there could be 2500lb inside. Do I need a 2000lb or 3500lb axle?
GregB wrote:Rich,
I'm using a Torflex #10 3500 lb. axle after talking to the engineers at Dexter for my 1600 lb. tear, though the rubber will be de-rated to 2K. As it turns out, you can run a 79" hubface distance with a frame that is only 48" wide by upgrading the axle. Normally you should have a maximum of 10" or so distance from the hubface to the frame rails where the axle is mounted and I have about 15.5". I have 15" wheels so there will be some pretty considerable weight hanging off the ends of those axles. My trailer sat too high with the wheels inside the body, so I am buying another axle (my third!) to put the wheels outside the body and lower the whole trailer. It's an odd situation, to be sure, but one reason to buy a #10 over a #9.
Greg
doug hodder wrote:For what it's worth...I always get more axle that I need from the get go....any variations in the design are covered, it's just not that much more weight or $$$$, 3.5K axle, 4" drop on the last 4 tears, but I build with springs, weights...between 960 and 1200#. Build what'cha want. Doug
TheOtherSean wrote: but once a few people are inside, there could be 2500lb inside. Do I need a 2000lb or 3500lb axle?
agpage wrote:TheOtherSean wrote: but once a few people are inside, there could be 2500lb inside. Do I need a 2000lb or 3500lb axle?
I am not an expert, but most trailers have some sort of stabilizers or jacks for leveling the trailer at camp. Those should help carry the weight of the sleepers.
Andy
aggie79 wrote:I bought the #9 Dexter derated to 1500# instead of the #8 because I wanted the 5-bolt hub.
kennyrayandersen wrote:I kind of don't get it. Generally the axles are rated for the weight you plan on carrying. They are designed to mitigate the shock based on that weight. It you are significantly over-capacity then it doesn't work as designed. When you get a extra big axle, you don't just get more capacity, or extra margin of safety, you get much more weight adn stiffness as well. ...
The weight of the wheels is insignificant in the overall axle loading.
kennyrayandersen wrote:agpage wrote:TheOtherSean wrote: but once a few people are inside, there could be 2500lb inside. Do I need a 2000lb or 3500lb axle?
Andy
Exactly! you only have to get the axle rated for the going-down-the-road wieght...
madjack wrote:...for a spring hung axle, you should have around a 50% overcapacity, a torsion axle as not as critical....
