I know it's possible as there is a chemical bonding used in the areospace industry for the same purpose. I need to know if this is worth thinking about ie. is it affordable and if so what is the product name.
Lee
xrover wrote:I would recommend you put some barrier between the al and the steel to prevent corrosion and oxidation. I own landrovers which are al skins and their trouble spots are always at the contact with steel.
why not go with aluminum or ss rivets? aircraft style I have thought make less imposing physical look.
Billy Onions wrote:if you can sort us a piece out. I can always find something test it on.
Dewi wrote:Billy Onions wrote:if you can sort us a piece out. I can always find something test it on.
PM me your address, I'll get a sample sent off to you asap... if the stuff I have at the minute isn't up to scratch, I can put you in touch with the best suppliers for the other types of tape... use a variety of tapes... the best I've come across comes from Tapes Direct... I think it was £30 a roll.
If I'm down your way soon, I'll bring what I have and you can test out with some decent lengths as well... the stuff I have at the minute was the leftovers from a job at Epsom race course. Used it to hang banners from the pillars in there.
Cheers, Dewi
Billy Onions wrote:96 square feet of 16 swg ally. At around 0.9 lb per sq. foot.
