Art Mini wrote:Thank you for your suggestion. Is an epoxy resin something I'd get at a boat supply store as opposed to a building supply ?
Art
Steve Frederick wrote:Someone here just posted about moisture damage to his roof. 'Glassing the seams (even under paint or metal)might have prevented the severe damage he experienced.
Just my 2-cents.
Steve Frederick wrote:I use 3.? ounce cloth from RAKA. I would only use cloth over panels that are assembled from sections of ply, with seams.
If you are not splicing sheets, and just want moisture protection, just coat with epoxy alone.
As Jack said, 3 or more coats, each done within 24-hrs of each other, will give good protection. Don't forget the edges!!!If you are 'glassing the roof (exposed wood), go with 4-oz cloth. Do a seal coat, then a lay-up, then a couple more coats.
If you are covering in metal, I'd do epoxy coats under the metal.
Just my 2-cents.
madjack wrote:Art, there is nothing wrong with that process...I would highly recommend using epoxy resin instead of "fiberglass" resin which is usually polyester based and is a lot less forgiving in regard to it's work time and is more brittle than the epoxy...put at least 3coats(a couple o'more if ya can)...if you wait more than 24hrs between coats, you will havvta sand before recoating...both epoxy and polyester resin need additional UV protection which can be accomplished with paint, spar urethane or auto clearcoat...for paint iI would highly recommend a marine topside or brightside paint...I prefer the non-blushing epoxy from www.raka.com ...others have used WestSystems, System3 or MAS...they are all good products.........
