West system 207 on 205 ?
Postby Dean K » Mon Mar 30, 2009 7:24 am
Hi,
I'm getting towards the end of my build and have decided to go with an epoxy/spar varnish combo for surfacing. My question is, can I do a couple of coats with 205 hardener then finish with one of 207 hardener? Is there any advantage/disadvantage to this - besides cost?
My sides will be stained wood, the top painted.
Thanks!
Dean K
Postby madjack » Mon Mar 30, 2009 8:01 am
DK, I will let those familiar with West Systems answer your question but will warn that many stains and epoxies do not play well with each other...water based stains or dyes(aniline) usually work the best with each other.....
p.s. I see this is your first post...so, Welcome Aboard...what part of the country do you hail from and what are ya planning on building...we will be wanting pics of your project...doanchano................MJ
Postby doug hodder » Mon Mar 30, 2009 9:59 am
The 207 is for clear applications when you want to show off the wood. Since you are going to top coat it with paint, you don't need to use the 207, you can top coat the 205. The link below has the product use chart and other good info. Doug
http://www.westsystem.com/ss/product-selection-chart/
Postby Dean K » Mon Mar 30, 2009 12:09 pm
Thanks for the replies everyone.
Hi madjack, I hale from Minnesota these days. My build is a modification of the "reverse-teardrop"... lower on the front, taller on the back - with a door on the back. I'd hesitate to call it a teardrop as it's more of a tiny trailer.
DK
Dean K
Postby Juneaudave » Mon Mar 30, 2009 2:01 pm
Most epoxy manufacturers test their epoxy with stain for adhesion. You might want to check West's test results for your particular product. West System over Stain
:thinking:
Juneaudave
Images: 380
Postby Dean K » Tue Mar 31, 2009 6:43 am
Thanks for the link - I had been planning on the Gel stain, but it's great to have some backup proof that it might work.
Dean K
