Page 1 of 1
2 Stroke Generartor and C-Pap system
Posted:
Sat Apr 09, 2005 10:01 pm
by kartvines
I just picked up a small two stroke 1000 watts generator. Wondering if any one had any experience with this small generator, and if it met their overall needs. I wanted to be able to run my C-Pap Machine, which I need to breath at night. This generator also has a 12volt connections, which I though would aid me, if I have no shore power, to run my 12 volt system. Feed back welcome.
If any one has installed a c-pap machine into their tear, I would welcome knowing how they did it. Where they ran the hoses, how they cleaned them and where they installed the machine. I thought I would have a location for my machine in the galley, but that is a lone run for the hoses, and I am lost in how to sterilize them without removing them.
Mike
Posted:
Sun Apr 10, 2005 6:51 am
by Syekick
As a former C-Pap of 8 years, here are my thoughts. I cleaned my mask never my hose. My C-Pap vendor and sleep study Dr only cared about the mask. The only discharge when exhaling goes through the ports in the mask. I don't see how anything can get back up the hose to be a significant health risk. But then I was a high pressure user, 12 cm H20. If I were concerned I would at a 12" extension to the regular hose so I could remove / clean it on a permanant installation.
I plan on charging my 12V system when on shore power so will use 12V for almost everything. I would hook the C-Pap up on the 12 V circuit on a interior cabin socket. Also, with 12V system you could camp in area's without shore power. I'd just build a small shelf on "my" side near the ceiling that would hold the unit. I'd wire a socket for the unit. I'd make sure it had sides so I couldn't pull it down on my head at night. I used the Solo unit which was quite small. With this method the entire unit would be as it sits beside the bed. Easily removable and cleanable. If I had a closet or storage at the head of the bed I might put it there instead.
C-Pap hose. Several years ago I was able to find a 10ft C-Pap hose on the internet for about $25. That gave me plenty of movement room for nearly all situations. That should give you plenty of length if you go permanant.
Another thought on permanant installation if I was going to do it. I'd plumb with PVC (figuring out the connectors might be a little tricky) and clean it with a stanitizing solution on a flexible synthetic "feather" duster.
Posted:
Sun Apr 10, 2005 7:26 am
by beverlyt
Mike,
I take it you have to run the C-pap machine all night long?
This is a new/good topic. I would think there might be people that have a need for power for different medical devices.
Having had asthma all my life, I invested in one of these:
http://www.pari.com/products/pariTREK.html
It is very small and portable. I charge the battery it comes with before I leave home. I'm also able to use it via 12v from in the tear or the car.
If I need it, it is tucked inside the teardrop in the back cupboard.
These machines only need to run for about 5 minutes at a time though. I could see where having something that had to run all night would require more.
Posted:
Sun Apr 10, 2005 8:02 am
by madjack
...KartV, I and I am sure others would like your impressions on the generator...specifically how loud is it and does it seem to be a well built unit
C-Pap and generators
Posted:
Sun Apr 10, 2005 9:47 am
by kartvines
My doctor tell me I must clean my hose at least every week, and my c-pap machine is only 120volt, I have seen others that are 12volts, but The V.A. does not offer that model. To others who are unsure of what the C-Pap machine does, it forces air down our nose and into to our air way helping our air way to remain open, in my case I stop breathing about 22 times a hour and with out the machine, which I have now been on for 7 years, and this machine run the entire time I am sleeping.
As for the generator, it a very small unit. I will give the report of it at another time, later on today once I have the details in front of me.
Mike
Posted:
Sun Apr 10, 2005 11:32 am
by catrinka
When we were tent campping Bob ran his c-pap machine off an inverter that was hooked up to the car battery. We never had any problems with it running down the car battery. In the trailer, we plan on building a shelf on Bob's side of the bed/trailer to house the c-pap. Bob is looking after figuring out the wiring in the trailer so I can't really tell you what he has planned there.
1000 Watts / 10 Amp small generator
Posted:
Sun Apr 10, 2005 5:01 pm
by kartvines
For those who wanted information about the generator I just pick up, the data is below:
Generator Model #ETQ-950 Ser #12004008617
Type TG1200
Operates appliance up to 10 amps
Use to charge vehicle battery
Runs 1,000 watts continuous w/ 12 volt DC outlet and 1 110 AC outlet
Approx 5.5 hour run time on single 1 gallon tank
In gas oil mix use 10W30 weight oil at a 50 to 1 mix
Feed back welcomed.
Mike
Noise rating 65 DB, sounds like a lawnmower
Weight 45.1 lb empty
49.6 lb with full tank
Overall dimension 15 5/8 in W X 12 5/8 in D X 13 3/16 in H.
Posted:
Sun Apr 10, 2005 5:24 pm
by catrinka
Are you planning on running the generator all night or just during the day to top up the battery? I would think that a generator that sounds like a lawnmower would be very annoying in a campground. Also I've noticed in my searching for campgrounds that a lot are stipulating no generators after 8pm.
Posted:
Sun Apr 10, 2005 6:31 pm
by mikeschn
I've been running a solar panel for a couple weeks now... I've decided against buying a generator. I feel it would be much too noisy for us. And the solar panel works so well. We'll probably buy a second battery as a backup... I'm thinking about a hawker odyssey battery. We have a small one for the trolling motor in the canoe, and it just keeps on going and going and going. The solar panel is so quiet, and my battery is topped off on a daily basis.
A few nights ago we started with 13.65 volts, ran the furnace and the propane detector all night, and ran the lights for a couple hours, and in the morning we still had 12.32 volts left. In other words, we only used 30% of our 84 amp battery. (The propane detector is a hog. I'm thinking about disconnecting it!)
But the bottom line is, for us, it's going to be solar all the way! Silence is golden, or something like that!!! It's cheaper too!
c-pap
Posted:
Sun Apr 10, 2005 6:41 pm
by kartvines
As far as running the generator all night, never wanted to, but unless I am to discover a way to run may machine all night on a 12 volt battery, then I am lost on knowing what to do, it is not like I have a choice of not using my c-pap machine, I was told by my doctor that it was a matter of life and or death. Still researching other ideas, it seems many people are using the c-pap machines. Maybe I will have to invest in another model, being only a standard 110 ac model is offered by the V.A.
Mike
Posted:
Sun Apr 10, 2005 6:56 pm
by mikeschn
I see 2 options... 1) buy an inverter...
http://www.cpapman.com/cpap.html#anchor8804
2) be sure to camp at campgrounds with a shoreline hookup!
Re: 2 Stroke Generartor and C-Pap system
Posted:
Sun Apr 10, 2005 7:18 pm
by Denzagrad
Mike asked:
"If any one has installed a c-pap machine into their tear, I would welcome knowing how they did it. Where they ran the hoses, how they cleaned them and where they installed the machine. I thought I would have a location for my machine in the galley, but that is a lone run for the hoses, and I am lost in how to sterilize them without removing them."
I have a CPAP in my tear. Its a 12V unit and I wired the front overhead compartment with wiring just for the 12V CPAP connection. I have enough extra 12v cord to move it anyplace in the cabin if needed. You can purchase the 12V electrical connectors for most 12V CPAP machine on line.
I also have a 120V unit. Before I obtained the 12V unit we had a power outage and it was a real pain. So, I went and bought the largest deep cycle battery Cost Co had at the time, also purchased a 700 Watt inverter. Using just the battery and inverter the 120V CPAP ran for 2 nights when the power went down. After two nights of running the inverter runnning the CPAP the battery was still about half charged - it only took 7 amps when first hooked up the charger.
As far as sanitizing. For short durations or when there is no time to do it right, I have used alcohol in a spray bottle and paper towels to clean the mask. If there is no water for washing, I bring sufficient replacement hoses for each night - they don't weight much.
Hope this helps.
Posted:
Sun Apr 10, 2005 8:00 pm
by catrinka
I had never heard of c-pap machines until 3 years ago when I met Bob. I am amazed at how many there are out there. However, Bob hasn't let it change his lifestyle. He still manages to go hunting and camping in the fall months. I will try to remember to ask Bob about the size of inverter he has.
