Looking for a Volkswagen van
Postby Marck » Mon Apr 20, 2009 4:52 pm
Want to build a tear to tow a tear
You want to build WHAT?????
40 isn't middle aged....
IT'S YOUTH PART II
Marck
Images: 64
Postby Miriam C. » Mon Apr 20, 2009 5:38 pm
:o :thinking: :twisted: OK. Now you know you gotta tell us how to do that. Course I might be the only person who doesn't know how. :R
Go for it!
Postby mechmagcn » Mon Apr 20, 2009 9:18 pm
If your luck with air-cooled VWs is like mine, it would be "tears" :crying2: to pull a tear
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Oasis Maker » Mon Apr 20, 2009 9:41 pm
Teardrop towing a teardrop? ... hmm :thinking: Oh - you must wanna be this guy?
http://www.youtube.com/watch?v=EA2pFtZ0cHg
Scott G.
Oasis Maker
Images: 187
Re: Looking for a Volkswagen van
Postby kennyrayandersen » Tue Apr 21, 2009 3:47 am
Marck wrote:Want to build a tear to tow a tear
OK, there are a couple of ways to do it, but the VW has a uni-body. You might get more flexibility from something with a frame. Then you could go crazy and not worry too much about the structure.
Otherwise, if you use a VW bus pan, you could go with a 68 or newer (rounded front window) -- you don't want to kill a classic and they are getting REALLY expensive anyway. Keep the front including the doors and door jams -- that will save you a lot of work. Then make the 'tear-like' part of it start to taper into the tear aft of where the front bench stops. The tricky part is that the roof is rounded so some place you have to either transition to the flat [up front?], or carry the curved roof-line all the way down (maybe not too easy) . Big project! :?
kennyrayandersen
Images: 38
Postby Esteban » Tue Apr 21, 2009 2:06 pm
If you want to buy a VW van Go Westy restores them and usually has a good selection of them for sale. Walking through their lot seeing dozens and dozens of VW vans is a very lusty experience.
Steve - SLO, CA
Esteban
Images: 15
