Windows vs. wind-holes
Postby artfd » Tue Apr 28, 2009 7:48 am
It seems most builders of trailers & RVs assume that all windows are meant to be opened. Often the only way for fresh air to get inside is through an open window/door or through gaps in the walls. Non-ventilating windows on side walls can be ridiculously simple.
5 years ago I built a wooden camper shell for my F150 using parts from an old shell and a few newish parts from RV's. I found a 3' by 1' horizontal opaque hatch at an RV recycler for $30 and used that to access & ventilate most of the extent of the shell from the right side. There was space on that side for a window, but I didn't need it to open, I just wanted a view port and a source of light.
:designing:
I cut a rectangular hole 9" square in my 3/8" plywood side wall, painted/sealed the wooden edges, put an 11" square piece of clear acrylic from the inside, seating it on a bed of silicon caulk, which also sealed the edges of the plywood to the surface of the acrylic. From the outside the window is recessed the thickness of the plywood with a bead of caulk all around, there is no window frame visible from the outside. From the inside the edges of the acrylic were secured to the wall, covered & trimmed with a very thin wooden molding rabbeted the thickness of the acrylic.
This window has been exposed to all weathers for 5 years and has not leaked, loosened nor needed any maintenance besides washing. The only flaw is a subconscious wish to see a external frame/molding around the window, though none is necessary.
artfd
Postby cokebottle10 » Tue Apr 28, 2009 1:45 pm
Sounds like a good idea. Can you send us a photo? :)
cokebottle10
Postby kennyrayandersen » Tue Apr 28, 2009 5:57 pm
It's not a bad idea, but I've noticed that a lot of builds are actually pretty tight. In that case, there won't be much infiltration of new air; so, if your window doesn't vent, there should still be a vent of some kind somewhere (door, roof, other venting window etc.). At some point you will need ventilation -- even if it doesn't come from the windows, or a particular window. This might be a good idea for the front window, or extra non-venting to suppliment venting windows.
kennyrayandersen
Images: 38
Postby mikeschn » Tue Apr 28, 2009 6:05 pm
I'd like to see a photo too!
Postby artfd » Tue Apr 28, 2009 8:18 pm
That's almost a subject for a different thread. I wanted to separate the design elements of ventilation from window-gazing and light entry. A design featuring ventilation for its own sake could have a vent down low and one up high, encouraging air movement even without a fan. We could also have posts on combining ventilation with other features, such as easing access to the interior.
Once it gets light out again, I will post photos of my work.
artfd
Postby Steve_Cox » Tue Apr 28, 2009 8:30 pm
I am partial to old fashion windows that open, but I also made 6 non-opening windows in my gypsy trailer and I have a picture from before trim and paint :D
Steve_Cox
Images: 196
Postby artfd » Tue Apr 28, 2009 10:50 pm
The really old fashion windows have no glazing, they are just holes cut in the wall! :throw PC:
artfd
