bronco wrote:I just wanted to double check with you guys first. when installing my aluminum sheets on the roof, it's the front sheet that overlaps the back sheet correct? The other question is at the front radius i am going to have a lap there as well and i've seen pictures of other tears with a lap there too, but the lap was back over the front at that spot. Would the purpose of that be for preventing any standstill water from working its way into the seam? What would be your best suggestion.
aggie79 wrote:I plan on using blue painters tape on the underlying sheet to both help align the overlapping sheet and to contain the sealant squeeze-out.
bronco wrote:Thanks brad. I do have a cheap pin nailer from home depot. It was supposed to be used for the headliner inside the tear but the bending force on the sheets of luan wouldnt hold with the nails and they popped through. Mybe it would work for this though.
