Miriam C. wrote::( I used sillycone and got it where I didn't want it. It doesn't come up and nothing sticks to it once it is dry. If you use it finish your wood really well first. And be very careful to not get it anywhere you might have to refinish....
green_eyed_diablito wrote:Miriam C. wrote::( I used sillycone and got it where I didn't want it. It doesn't come up and nothing sticks to it once it is dry. If you use it finish your wood really well first. And be very careful to not get it anywhere you might have to refinish....
i agree. nothing will stick to it after it dries. i made that mistake when i installed windows in my house (i forgot about that).
bronco wrote:thanks for the replies everyone. It always helps to go into a project with every possible problem thought out ahead of time. It never fails though something finds a way to bite me in the butt no matter how much prep work was done.![]()
I know there will be some squeeze out when i screw the sheets down and i'll have to clean it before it dries. Any recommended cleaning solvents you would all use?
Thanks again for your advice it helps.
Walt M wrote:Hey Kids, from what I've learned, you can dissolve Silicone while your working with it using Isopropyl Alcohol (is that spelled right?). In my experience silicone does break down a bit under uv ( at least the "clear" type. Whenever I need this type of product I use Geocel it's a trypolimer sealent a bit more money but much more durable. imo Walt
