I made a piece of aluminum and cut the intake and exhaust holes. I put a rubber seal around the edge and use the hoses to just press up against my open window. I tested in the heat of the day and it worked great.
IndyMatt wrote:I found an old plastic light fixture that fit perfectly over the roof vent in my Little Guy. I cut a notch in the arm of the crank so that I could relase the vent cover and put my light fixture cover over it. Here are the results:
Users browsing this forum: Google [Bot] and 8 guests
