I hear some using exterior primer and paint with no epoxy is that a mistake
I am not building the Taj mahal but don't wanna short change myself
Thanks
Dan & Julie CO wrote:Wow very informative I'm planning to use durhams water putty for filler mostly because I have some already will the epoxy penetrate ok?
madjack wrote:Dan & Julie CO wrote:Wow very informative I'm planning to use durhams water putty for filler mostly because I have some already will the epoxy penetrate ok?
...dunno...never used it, myself...you might ask Larry at RAKA or the tech people at Durhams about compatibility issues...hmmmmmmanother thought...I wonder if you could mix the dry "putty" powder(gypsum) with the epoxy to make a water proof filler/fairing agent...........
