Lil bear premade doors
Postby Mike_La » Sun Jun 14, 2009 8:05 pm
pb,
I'm not familiar with those exact doors, but from others I've seen, they're filled with Styrofoam(which as you know is a good insulator.
The ad state they are aluminum, so they're paint-able.
As for leaks, these type doors usually seal well.
Hope this helps,
Mike
Mike
"Believe you can and you're halfway there."
Theodore Roosevelt
Mike_La
Images: 71
Postby len19070 » Sun Jun 14, 2009 8:41 pm
If Grant Whipp is selling them they have been tested, inspected, subjected, carbon Dated, certified, rectified, fortified and approved.
Anything he sells is the best for what he recommends it for.
I have been dealing with Grant for years, I would blindly buy anything he recommends as being the best.
A lot of experience there.
Happy Trails
Len
len19070
Images: 24
Postby madjack » Sun Jun 14, 2009 10:29 pm
...in total agreement withLen...ya just can't beat Grant's...stuff :thumbsup: ............................. 8)
Postby jdarkoregon » Sun Jun 14, 2009 11:19 pm
I agree with those above, and Grant is easy to deal with, call him, ask whatever questions you have.
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Re: Lil bear premade doors
Postby grant whipp » Mon Jun 15, 2009 2:24 am
powderburn wrote:Has anyone tried them? ...
I've sold a bunch of 'em ...
... Do the leak? ...
NOPE!
... Can they be painted to match the trailer? ...
Yep!
... Are they insulated? ...
Sort of. The core of the door is just under 1/2" styrofoam sheet bonded on both sides by .035" aluminum sheet. If you want/need serious insulation in these doors, I'd recommend fitting a snap-on inner cover that is vinyl on the door side and fabric on the inside with an inch-or-so of foam-rubber or perhaps some of that foil-backed insulation sheet. If these doors have any drawbacks, this is it (and the fact that I can't get them in anything but white aluminum with black frames ...).
Drop me a line if there is anything I can help you with! As always, then ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby KDOG » Mon Jun 15, 2009 10:44 am
Good stuff. I need a bigger door for my build but I WILL be probably getting 2 of the black curved frame slider windows from you....
FAILURE TO PLAN ON YOUR PART DOES NOT CONSTITUTE AN EMERGENCY ON MY PART.
KDOG
Postby smarttech » Thu Jun 18, 2009 2:34 pm
Grant, I'm hoping to place an order sometime soon for a couple of your big 32" x 36" doors with sliding windows in them and probably a galley hinge. I just have to get the money together first. The doors have been my stopping point because I can't really move forward without framing in the correct size for the doors. I have searched around for pre-made doors and keep coming back to your site as the best solution for me. I'm just afraid that shipping is going to drastically increase the price. It's very nice to hear other people's opinions of your character. I like dealing with people that can be trusted.
NOPE!
Yep!
CHEERS!
Grant
Steve Martin
Smart Technology
smarttech
Postby dguff » Thu Jun 18, 2009 10:56 pm
I bought and installed the 32" by 36" doors with the sliding windows from Grant. I used them to replace the original doors on my Guffman. I was never happy with the original doors because there was a slight warp in the plywood. The new doors fit just fine and it was pretty easy to enlarge the opening in the wall for them. They are very well made and did not leak at all during the very wet Dam Gathering. They have a nice rubber gasket seal all around the door opening. I have not painted them yet but intend to in the very near future.
Jerome :D :D
Jerome
2008 Guffman
dguff
Images: 69
Postby grant whipp » Fri Jun 19, 2009 3:35 am
smarttech wrote:... I'm just afraid that shipping is going to drastically increase the price ...
Hiya, Steve!
S&H for a pair of those doors to UT will be in the $90.00 range ... probably not as bad as you thought, huh ... :thinking: ...?
CHEERS!
Grant
grant whipp
Images: 117
