Bolt holes not lining up
Postby Forrest747 » Sun Jun 14, 2009 10:55 pm
Ok i predrilled the holes in the chassis frame to the floor frame after i add assembled it. i even bolted the frame to the floor when i applied the plywood deck and now that i have waterproofed the underside flipped over and want to bolt the floor to the chassis the holes at about 1/4 inch off meaning i cant bolt it.
I am thinking i am trying to bolt it when it was cooler when i predrilled the holes, chassis shrinkage. is this possible? or do i just enlarge my holes from 3/8 to 1/2 inch. i can still do a washer with the flange bolt or do you think i could go with 1/4 inch bolt instead of teh 5/16.
Forrest747
Cowbell Donating Member
Images: 447
Postby Kevin A » Sun Jun 14, 2009 11:17 pm
Are you sure you don't have the floor rotated 180 degrees from when you drilled the holes? If ya flipped it lengthwise the first time and flipped it back over from side to side, you're gonna be out 180 degrees.
Kevin A
The other guy
Images: 289
Postby Forrest747 » Mon Jun 15, 2009 12:12 am
nope the floor is in the correct position. first thing i checked.
Forrest747
Images: 447
Postby kennyrayandersen » Mon Jun 15, 2009 4:11 am
So you could remove the bolts from the cabin and relocate them (I would have drilled on assembly) – plug the hole with a wooden dowel and re-drill; or, you could weld up the holed in the trailer, grind them flush and re-drill. Another option might be to slot the hole in the trailer and the just install the bolt with a decent washer. :thinking:
kennyrayandersen
Images: 38
Postby doug hodder » Mon Jun 15, 2009 9:13 am
Did it get out of square when you predrilled, or when assembling? Now that is there, drill it out, stick in a larger bolt. That's what I'd do. Doug
Postby Forrest747 » Mon Jun 15, 2009 11:38 am
What i did was used a block and tackle and adjusted teh floor to match up the hole and hammered those suckers in. worked like a charm. i did have to enlarge one hole other than that i feel good about it.
Question though do you just put bolts on teh sides or do you have any on teh front as well.
Forrest747
Images: 447
Postby Larwyn » Mon Jun 15, 2009 4:06 pm
I only put three 3/8" carriage bolts per side. But you may never know that, because I know I replied to this thread this morning and my reply has not shown up here yet.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby Forrest747 » Mon Jun 15, 2009 9:20 pm
I put I am assuming grade 2, 5/16 bolts. i put 4 on each side. I had drilled enough for 5 in teh chassis. I also drilled 3 in the front and two at the rear. However have not placed the bolts in as of yet. there is always tomorrow.
Forrest747
Images: 447
Postby Larwyn » Mon Jun 15, 2009 9:36 pm
Forrest747 wrote:I put I am assuming grade 2, 5/16 bolts. i put 4 on each side. I had drilled enough for 5 in teh chassis. I also drilled 3 in the front and two at the rear. However have not placed the bolts in as of yet. there is always tomorrow.
General Motors only used four 3/8" bolts to hold the bed on my Silverado, I think the 6 I used for the TD will be more than enough...... :thumbsup:
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby kennyrayandersen » Mon Jun 15, 2009 11:22 pm
:lol: :lol:
That tear ain't going no where!
kennyrayandersen
Images: 38
Postby Roly Nelson » Thu Jun 18, 2009 12:57 am
Only George on the Seinfeld show, has a problem with shrinkage...........If the holes don't line up, ream 'em bigger and use a fender washer to hide your corrective measures........Poor George.
:( :? :x ;) Roly
Roly Nelson
L'il Ol' Woody Builder
