Some general planning questions prior to construction
Looking into my first build and had some general questions that I've seen some answers mentioned, but I would like to ask again to see if there are any renewed opinions or links to articles I'm missing (there is a plethora of information on here)
I have a 4cyl to pull my future TD with, so I need to keep weight down:
- Would sandwich construction be lighter than 3/4 ply? (Assuming 3/4 based on some of what I've been seeing) I have several sheets of 1/4 luan laying around and several sheet of left over R-tech insulation from the building of my shop.
- Would coating the outter shell in fiberglass add too much weight as compared to aluminum or other sheeting materials?
- Should I not insulate the roof and sides if I only plan on camping during the hot months in the midwest (April-October)? I don't plan on installing an AC unit, only a hatch fan and 2-3 windows.
- Are the lightweight bolted frames (homemade I guess) with torsion axles very much of a weight difference over buying a leaf-sprun trailer to assemble?
- To cut the arcs for the hatch bows (etc.) do you just lay them out on a sheet of 1x12, 2x12, whatever fits the arc onto one sheet of lumber? Or is there a page I can read with a how-to?
Thanks for the help in advance!
