Newbie needs your opinion
Postby mlsa » Fri Jun 26, 2009 12:28 pm
Hello Everybody
I just registered today. I've been reading your forum for the last couple of weeks and I want to thank all of you for posting such great info and for posting such excellent pictures of your work. You all have my admiration.
You now have me wanting a teardrop. BUT..for now I have a harbor freight trailer with a car top carrier that I pull behind my Goldwing Trike. It carries all my camping gear. I need a larger trailer for a tear drop and a place to store it since my garage is full and my boat storage is full.
Being a woodworker, I've wanted to take the car top carrier off the trailer and build a fancy wooden box...Here is the style I will probably end up with:
http://www.classictrailersalesinc.com/a ... /index.htm
I know this isn't a teardrop but you folks are professionals with this type of woodworking and hopefully can answer a few questions for me.
The trailer is 40" wide and 48" long...box length and width. I was thinking of making the sides out of 1/2" plywood and the top out of 3/4" plywood for adding strentgh in case I needed to strap something on top of it. It would have a door on top. It would strictly be for hauling around my camping gear.
Then for the fancy part I was thinking of gluing very thin pieces of wood such as teak, oak, walnut, etc over the outside of the plywood. Of course it would have to be trimmed out. I was also thinking of making a wood railing all around the top of the box. Then sealing everything where it would be waterproof. If you've ever seen a wood stip canoe or kayak..then thats sort of the look I'm thinking of.
Does this sound reasonalble to you folks? Will the 1/2" plywood with thin strips glued to it work? Will this hold up to highway speeds?
Even though weight is always important when pulling a trailer I know folks that pull their camper trailers loaded close to 500Lb with their goldwings.
Thanks for any help or advice you can give me \.
David
mlsa
Postby toypusher » Fri Jun 26, 2009 12:46 pm
David,
First of all, Welcome to the board!!
I like the look of that trailer. Are you going to use anykind of framing on the inside. If so, you could easily use 1/2" for the sides and the top, I would think. Just use some 3/4" x 2 or 3 and frame it out and then use some poplar for spars to support the top. Actually, if you do that, I think that 1/4" would work fine. Especially since you are then going to cover it in strips too.
Looking forward to some pictures!
toypusher
Images: 324
Postby madjack » Fri Jun 26, 2009 1:07 pm
...yep, everything Kerry said...I would use epoxy to apply the veneer and seal it...a couple(r3r4) of coats of a spar urethane or auto clearcoat to protect it from UV rays and you will be set to go...with a REALLY nice looking trailer...............
