by madjack » Mon Jun 29, 2009 11:33 am
aggie79 wrote:WayneFromMo wrote:I'm not finding any sealers talked about in the forum locally. Would Thompson water seal work? I plan to paint over it with an acrylic automotive paint.
Short answer - "no." Most Thompson water seal uses silicone with solvents. Paint won't stick to it.
...absolutely correct..original Thompson's had paraffin(wax) oils, latter/fancier stuff had silicones...and paint will not stick to it...a much better choice would be to contact
www.raka.com and get a gallon of epoxy...put at least 3 coats of epoxy on to seal everything and then paint with whatever you wish...automotive or marine paints are good choices over epoxy.....
p.s. a tip...you will want to relieve the corners of all wood so you don't have a sharp 90* angle...paint/epoxy will crack/fail along a sharp edge.........MJ
