Questions on side walls and insulation?
Good Morning Everybody
After reading more of your building reviews I have a few questions if you don't mind. I've used the search but didn't find answers to these questions.
Side Walls: I see where some use a sheet of plywood without a frame and some build a frame and then skin on both sides.
What's the end difference in the two?
Which way would end up being lighter if any?
If I went with plain plywood instead of framing/skinning, would I use 1/2" or 3/4" plywood?
Insulation: I see everybody is using block insulation. Why could you not use regular bat insulation like in the walls of a house? Seems like it would be easier to install.
Thanks for any replies and suggestions.
David
David
