rear hatch lil guy 5wide
Postby okiecamper » Mon Jul 06, 2009 8:32 pm
inside my rear hatch, or galley if you please, there is a "raise-up shelf"
it covers most of the area, except for about 8" so you can see down into
the cabin.
its made of really heavy material, I don't know what it is, but it is quite heavy
to lift up and hold, because there is nothing to hold it up and open.
I'm thinking its like 5/8" material
painted while.
I want to take this out and replace it with a 1/2" plywood 49' x 27 1/2"
and cover the whole opening.
that way, the whole galley area has a solid working area .
i think 1/2" plywood would be strong enough and less weight.
any ideas??
thanks
Phil
there are many storms in life that come our way
the trick is learning to "dance in the rain."
May the apple of your eye see only good
May God make smooth the path before you.
okiecamper
Postby okiecamper » Mon Jul 06, 2009 8:33 pm
sorry not 49' x 27"
its 49" x 27"
thanks
Phil
okiecamper
Postby skulli69 » Mon Jul 06, 2009 8:41 pm
Mike & Tracy
2009 Silver Shadow Highline 5X8
skulli69
Images: 21
Postby wlooper89 » Tue Jul 07, 2009 4:02 am
The link in the previous post is the best I know. I have a Little Guy six-wide and the problem you mentioned is the same but more so. The shelf should be made of lighter material. The hinges that hold it should be stronger. And the shelf support at the rear of the trailer should be more solid. I believe the topic mentioned in the previous post shows a vertical support that does not take away sleeping area space. This is one possibility.
Bill
wlooper89
Images: 75
Postby okiecamper » Tue Jul 07, 2009 6:33 am
thanks wlooper89,
i saw that thread, i'll look at it again.
thank you very much.
phil
okiecamper
