Page 1 of 1
Does anyone know what will dissolve lithium grease?
PostPosted: Fri Apr 22, 2005 11:55 am
by Joseph
I used blue lithium grease on my HF bearings and can no longer get the same stuff. I'd like to switch to a synthetic grease but I understand it's a bad idea to mix lubricants as they can work against each other and break down. Basically, I need to clean the old lithium grease out of my bearings but to my surprise acetone doesn't cut the stuff. Anybody know what does?
Thanks,
Joseph
PostPosted: Fri Apr 22, 2005 12:08 pm
by Nitetimes
lacquer thinner
PostPosted: Fri Apr 22, 2005 9:20 pm
by nickster60
parts cleaner, I think kerosene will also do the job
PostPosted: Sat Apr 23, 2005 1:03 am
by MikeR
Gasoline will too but it's expensive!
PostPosted: Sat Apr 23, 2005 1:07 pm
by Joseph
MikeR wrote:Gasoline will too but it's expensive!
I don't know why I thought I'd used lithium grease. :thinking: When I pulled the canister out of the grease gun it was plain old general purpose grease. But in any case, gasoline did the trick. :thumbsup:
Thanks,
Joseph
PostPosted: Sat Apr 23, 2005 10:38 pm
by steve wolverton
Joseph wrote:But in any case, gasoline did the trick.
Gasoline is a miracle liquid. It does everything, and you can sniff it. :?
Grease
PostPosted: Sat Apr 23, 2005 10:53 pm
by OkieSailor
Next time try WD-40. Even on old caked grease zips right off, also good on road tar on the teardrop. Spray and lightly rub.
