woody cub, questions
Postby Aaron Coffee » Thu Jul 09, 2009 4:46 pm
think I have decided on going with a cub profile and doing it as a woody. Kind of thinking using white aluminum for the top. How would that look? Anyone have any pics of a woody cub? Just to get this straight, is it recommended to coat all sides of the plywood with epoxy, or just the outside and edges? What about roof, if I use aluminum? Recommendations on which epoxy system to use? Leaning towards CPES as 50, 50 mix seems easier to get right. Every time I mix body filler or pc7(2 part epoxy filler)j-b weld, seems like I get too much or not enought hardener so it either dries to fast or never dries.
Thanks
Aaron
Aaron Coffee
Images: 26
Postby chorizon » Thu Jul 09, 2009 5:34 pm
I don't recall seeing a woody with an aluminum roof. You'd be the first! I think it sounds like it'd look really cool. I wouldn't think there would be too much more to consider compared with the epoxy/paint sides w/ the aluminum roof.
Hope others concur, I'd like to see it! :thumbsup:
chorizon
Images: 94
Postby kennyrayandersen » Thu Jul 09, 2009 5:55 pm
Personally, I think the white might washout a bit with the white if you use a lighter would like red oak finished natural, beech, or ash. It seems like if you have a bit of contrast that it might make the trim pop out a bit. White oak finishes natural as kind of a cocoa powder color, which might be nice, but after looking through all the pics I think that the polished aluminum, if you are going to use aluminum looks pretty fine.
kennyrayandersen
Images: 38
Postby xrover » Thu Jul 09, 2009 7:10 pm
While I just sold it, my TD had luan grained sides and aluminum wood. If that is what you mean.
My gallery still has those shots in it.
1988 Cadet
2006 Argo Avenger
xrover
Images: 22
Postby doug hodder » Thu Jul 09, 2009 10:31 pm
Aaron....I've done a couple of tears with an aluminum roof and wood sides. I only coated out the exterior sides and the edges, but put a lot of time and effort into making sure those edges were completely sealed. I didn't bother to seal the sub ply under the aluminum on the roof. I didn't float the roof, used Roberts swimming pool carpet cement under it, troweled on with a notched trowel. West System epoxy with the metered pumps will ensure a perfect cure every time, I've been using it for 10 years now. Other epoxy systems will work as well, but I'd highly recommend the metered pumps. Doug
