Balance Left to Right?
Postby Donutboy » Fri Jul 10, 2009 11:58 am
So on my build, I have a microwave, air conditioner, port-a-potty, storage cabinet, and RV power converter on the left. On the right I have the door and a thermoelectic refrigerator. I am deciding where to put the battery. It would be much easier to mount it on the left (same cabinet as the RC power converter) but something tells me I should put it on the right to help balance things out left to right. Will it matter?
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby Miriam C. » Fri Jul 10, 2009 3:12 pm
:shock: Keeping the balance might not matter now but as your springs settle it might.
Postby McBrew » Fri Jul 10, 2009 3:58 pm
Balancing it out is easy: Put a keg of beer in the fridge!
-Jesse
1984 Scamp 13'
In the process of bringing it back to its former glory... if not better!
McBrew
Postby Gary and Cheri » Fri Jul 10, 2009 5:25 pm
I don't think balance right to left is all that important, but balance front to back certainly is. Check your tongue weight and select a location that will help that.
Gary
Gary and Cheri
Postby caseydog » Fri Jul 10, 2009 6:05 pm
Oh, teardrop balance... I thought we had another political thread started. :lol:
Yes, it will matter, to a degree. A few pounds off will not matter, but if you can see the TD lean, I would suggest you try to balance it out better.
I use my gear to balance my TD front-to-back, and I'm sure you can do the same side-to-side.
CD
My build journal is HERE
caseydog
Images: 515
Postby 48Rob » Fri Jul 10, 2009 6:26 pm
Yes,
Side to side weight balance is very important for good handling!
As Casey stated, a "few" pounds won't make a big difference, but it is very important to keep it balanced to at or near the factory plan.
They did it the way they did it for a reason...
Rob
48Rob
Postby Jst83 » Fri Jul 10, 2009 7:19 pm
McBrew wrote:Balancing it out is easy: Put a keg of beer in the fridge!
Only good on the trip there how about the return trip
Jst83
Images: 215
Postby Donutboy » Fri Jul 10, 2009 7:58 pm
On the return trip the keg and potty have to swap sides. 8)
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
