Bending Plywood
Bending Plywood
Postby crazycyclist » Mon Jul 13, 2009 8:28 pm
I'm working on my galley hatch and have the frame finished. Before I skin it I want to be sure my plywood is bent properly to avoid springback. I was talking with greekspeedoman today and heard his frustrations and have heard rumors of others. What's the best way to ensure your hatch doesn't spring back out of shape?
EDIT: I did find this article very helpful. http://www.woodweb.com/knowledge_base/R ... _Wood.html
What do you think of Bendable Plywood or Whacky Wood?
Still looking for ideas and tips.
Mel
Orlando, FL
www.melwade.com/teardrop
“The illiterate of the 21st century will not be those who cannot read and write, but those who cannot learn, unlearn, and relearn.” -Alvin Toffler
crazycyclist
Images: 24
Postby Steve_Cox » Mon Jul 13, 2009 9:50 pm
Bendy plywood is too flexible to be of any use on a hatch exterior, but I'm sure there are exceptions to that statement.
Some people wet the plywood before bending, some use 1/8" plywood, I used 1/4" and just bent it, but after hearing all the spring back stories, I made my hatch spars with 3/4" more curve than the side profile. It worked for me, results may vary.
Steve_Cox
Images: 196
Postby kennyrayandersen » Tue Jul 14, 2009 5:25 am
If you use plywood ribs they should be pretty stable (as opposed to bent wood). If you couple that with bendable plywood or some 1/8 plywood, and epoxy or tight bond the plywood (inside and outside), I can imagine it should change shape too much. Also, if you keep it battened down (latched) it will keep a preload on it which will not allow it to bow back out straight. I forget who it was, but galley latches came up. He had a latch on both sides at the bottom (structurally this is the best place to put it to give maximum mechanical advantage when you are trying to make it conform to contour). I plan on getting around this by hotwiring the hatch out of rigid foam and then glassing it. There won’t be any preload in the door then to try and make it spring back.
One other thing, and I know it’s been mentioned before is to build the hatch first, then trim the tear to match. One advantage doing it that way is you could let it sit for a month or two and it would likely get to a position of quasi-equilibrium and then you wouldn’t have to worry so much about it opening further.
:thinking:
kennyrayandersen
Images: 38
Postby TPMcGinty » Tue Jul 14, 2009 6:32 am
I used bending plywood on the exterior of my tear. I didn't have a problem.. I kept the spares fairly close together.
Tim
TPMcGinty
Images: 146
Postby Rock » Tue Jul 14, 2009 7:37 am
I'm kerfing the backside of the 1/4" plywood that I'm skinning the tear with.
Eric
Rock
Images: 48
Postby Mini Renegade » Tue Jul 14, 2009 3:59 pm
TPMcGinty wrote:I used bending plywood on the exterior of my tear. I didn't have a problem.. I kept the spares fairly close together.
Same here, 1/4" bendy ply, not the stuff with grooves in though, it has 3 layers with the centre one running length wise and the others across.
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby crazycyclist » Sun Jul 19, 2009 9:13 am
Thanks for the feedback. I've purchased 1/8 oak and have found it very easy to work with.
Mel
Orlando, FL
crazycyclist
Images: 24
Postby kennyrayandersen » Sun Jul 19, 2009 6:13 pm
crazycyclist wrote:Thanks for the feedback. I've purchased 1/8 oak and have found it very easy to work with.
Did you have any trouble finding that in 5 foot wide?
kennyrayandersen
Images: 38
Postby crazycyclist » Sun Jul 19, 2009 10:53 pm
I'm just putting a seam in it.
built a steam tent and steamed a piece tonight. We'll see what it's like in the morning. I don't think I got it steamy enough.
Mel
Orlando, FL
crazycyclist
Images: 24
Postby starleen2 » Mon Jul 20, 2009 10:49 am
crazycyclist wrote:I'm just putting a seam in it.
A Sauna??
starleen2
5th Teardrop Club
Postby 2bits » Mon Jul 20, 2009 11:15 pm
Baltic Birch is known to be pretty bendy, not enough for my inner radius though (or maybe not my patience) but it is really bendy. I almost got it to work, but decided not to pursue it and am going for the black aluminum since I already have it.
Thomas
2bits
2bit Member
