LiLREd wrote;
I have a question here that is probably a no brainer for y'all that restore trailers, but I haven't even started and I need to know basic information.
The most important first step is to take a lot of pictures.
The higher the resolution, the better.
Tke shots of everything, inside and out, then take a few more closer up.
Photos are a real lifesaver when putting things back together.
For instance, if I wanted to remove the aluminum skin from my Kenskill to check the framing inside for rot and replacement, could I put the same skin back on, or will taking it off destroy it for future use.
As long as due care is taken, the skin can be re used.
Should I bank on having it professionally reskinned?
It would depend on your skill level, and also on what facilities you have for storing/working on the trailer.
It would be very sad indeed if you had several panels off, and you got a week of steady rain...
Will I have to replace the metal trim that goes along the edge or can that be reused?
50/50, Sometimes it can be reused, and sometimes it becomes too damaged during removal to look good if re used.
The same, or very similar edge trim is still available, and new is much easier to install!
Can I do one section at a time or will I have to remove it all at once?
Wall sections can be done a little at a time, and in fact, is probably better done that way unless you have a lot of experience.
When done a little at a time, the trailer will be much more likely to maintain its current shape.
Sometimes when you try to take it all apart at once, it can be rather overwhelming, especially if there is a lot of rotten wood. It is best to maintain structural integrity (don't want parts falling off/down)
It is easier to prevent damage from a summer thunderstorm if there is just a small section to cover.
Rob
