Do they make this type of bolt washer?
Postby Galen » Thu Jul 16, 2009 10:11 am
Hi Folks, I have a hardware question.
I am going to bolt my tear drop to it's frame, and the bolts are going to be inside the composite walls.
I was thinking that I would leave small cutouts inside so that I could access the bolt tops to keep them tight, but then I had an idea.
Do they make a bolt washer that grabs the bolt head, and that has teeth that sink into the wood to keep the bolt from spinning?
If so, do you have a link to where to get them and what are they called?
If there is such a thing then I won't need to leave little access holes that would not be as attractive and would be an insulation leak and be extra work to make.
Thanks again!
Galen
Galen
Postby doug hodder » Thu Jul 16, 2009 10:18 am
I think you are looking for a T nut. Check your local hardware store. Bolt runs through the back side and sucks the teeth into the wood. For keeping them tight....use some loc-tite. Doug
Postby planovet » Thu Jul 16, 2009 10:19 am
Sometimes called torque washers
Link (scroll to bottom of page)
ImageMark (& Cindi)
planovet
The Cat Man
Postby Galen » Thu Jul 16, 2009 10:50 am
Perfect! Thanks for the link. I figured they had to make such a thing.
And yes, I will use loc-tite, but I am going through several thicknesses of wood, which after time may dry and compress a bit, so I may need to tighten them up once in awhile.
Galen
Postby cokebottle10 » Thu Jul 16, 2009 11:14 am
If you need a nut then "T" nuts will be the best. If you need a bolt then "elevator" bolts with teeth will be what you need. Elevator bolts look like carriage bolts but they have a larger flat head. Fastenal or any industrial nut and bolt supplier should have them. You can look them up on line in the "Granger or MSC" catalogs. 3/8 is a common size. These are also good for attaching the fenders. You can even get them in stainless steel if you want.
David.
cokebottle10
Postby Larwyn » Thu Jul 16, 2009 12:55 pm
I used simple 3/8" carriage bolts. No reason to over complicate things. the square shoulders will hold the bolt while you tighten the nuts from below.
Larwyn
Larwyn
Mad Kilted Texan
Images: 210
Postby kennyrayandersen » Thu Jul 16, 2009 6:36 pm
One other option is a threaded insert which I've used on occasion. Drill a hole, screw in the insert, and the you can screw the bolt into that. You can get them from any of the woodworking hardware placed and come in #10, 1/4, and I think I saw them in 3/8 (which is mighty big!). You would need hardwood, preferably, burried in you composite panel (this could even be a foam panel with the insert made from a hardwood, or plywood plug or dowel (or even solid epoxy with some chopped fibers mixed in. This can also be done after the factby drilling a small hole, and hogging the inside out with the short end of a Allen wrench using a drill. Drill small hole, fill with epoxy, drill and insert through bolt, or use a panel insert (Sur-loc makes several and their manual tells how to install them).
kennyrayandersen
Images: 38
Postby Miriam C. » Thu Jul 16, 2009 9:59 pm
I used T-nuts. They are still tight and they are recessed so They are where I want them not just on the sides. :thumbsup:
