Undercoating
Undercoating
Postby GeneH » Thu Jul 16, 2009 9:32 pm
I was thinking of putting a coat or two of CPES on the underside of my TD floor before applying the evil smelling, gooey Gardners green can stuff to it.
Has anyone done this or is it even necessary with the Gardners?
GeneH
Images: 34
Postby planovet » Thu Jul 16, 2009 10:12 pm
Whether it is "necessary" (or not) is debateable. Some say yes, some say no. I wanted to be extra safe so that's what I did. Two coats of CPES and a thick coat of the black goo.
ImageMark (& Cindi)
planovet
The Cat Man
Postby S. Heisley » Thu Jul 16, 2009 11:20 pm
Hi, Gene:
I thought about doing it but didn't. I used 3+ coats of CPES instead. I did write to the Rot Doc and ask them. Here is my question and the answer I got:
S Heisley wrote:
... Will the the roofing tar adhere to the CPES
> treated wood? Will these products work together okay?
> Thanks, Sharon
Sharon,
They will, as long as the CPES'd surface is not glossy. You might give the surface a light sanding with some 175 (or similar) git paper before applying the roofing tar.
Doc
-- The Rot Doctor
Postby aggie79 » Fri Jul 17, 2009 8:13 am
I'm using three coats CPES - cured and sanded - followed by a light coat of spray rubberized undercoating. (I still need to do the undercoating part.)
:thumbsup: Gig'em, Tom
Postby Sam I am » Fri Jul 17, 2009 8:32 am
I used a coat of Roofer's Pride roof patch from Wal-Mart brushed onto bare plywood. Actually, brushed isn't the word. The stuff is as thick as peanut butter, so it was more like squeegeed on with sticks. It has worked well for 3 years of towing through several hard rainstorms, and one winter run over wet, salted roads. No water penetration into the floor at all! You might not need the CPES.
Sam
Sam I am
Images: 106
