SIPs and foam and aluminum, oh my!
After writing this whole thing, I thought I'd go back and preface it with an apology for the brain dump. If you decide to hit "back" now, I won't blame you one bit.
I'm in the dreaming-about-construction techniques phase of my TD build. AKA, I already have too many irons in the fire, and don't even have room in the garage until I finish siding the house. Anyway, I posted a thread earlier about my main design constraints, that it be very lightweight (<500 pounds loaded) and very low profile, about the same height as a Miata (48").
Also, I have an interest in building it completely out of non-organic materials, primarily aluminum. I was enamored with aluminum honeycomb panels for a while until I sat down and figured what they cost.
I realize that wood is used for good reason- it's relatively light and strong, but above all cheap. My problem is that it rots and otherwise has a tendency to deteriorate. Besides, I just like to be different.
When thinking about how to build the frame, I kind of settled on Andrew's ultralight a-frame as the ideal combination of weight savings and strength for my comfort level. Figuring out the lower platform was my next task, and I came across this thread where captainsam did some really interesting testing with laminating foam and luan into relatively lightweight panels (SIPs) that ended up being VERY strong. I'm really curious to see how 2" of Foamular 250 XPS (AKA pink foam board) laminated with .04 aluminum in a vacuum press would perform.
So I had a couple construction techniques that pushed all the right buttons with me, and I wondered if there was a way to combine them. While driving home this evening, I thought about building the frame (out of 2" square aluminum tube) and axle pretty much as usual, but sandwiching it inside the SIP with a 2" foam core. To retain the strength of the panel, I know I'd have to cut the foam around the frame to very close tolerances. Then I got to thinking about building the side panels similarly, most likely out of thinner foam, and embedding tubing where it would be necessary for fastening bulkheads and walls.
So what's wrong with this plan? I know it would take longer and be more expensive than more traditional methods. It would also require very careful design and construction. There are details yet to be worked out, such as how to join the roof and floor to the walls. And it might not even save any weight in the end. But to me, going camping in the thing is almost secondary to building a neat project. There are lots of big brains around here, I'd be very interested to hear what flaws these techniques might have that I haven't foreseen. Thanks in advance for the input.
Josh
Josh
