Page 1 of 2
securing cabinet doors
Posted:
Sun Apr 24, 2005 10:04 pm
by moonday_55
I am in the planning/dreaming stages 'cause I can't start building for about 2 or 3 years. I'm still in school and it's hard to build in a dorm room.
anyway, has anyone used babyproofing door latches with a basic nob pull on the cabinet doors. I am trying to keep things simple.
thanks
Posted:
Mon Apr 25, 2005 2:58 pm
by josephhanson
Keeping it simple...I used a piece of wood 3/8 X 1 1/2 with a bolt through it placed the wood/bolt centered between the caninet doors, and put a spring on the inside of the cabinet,over the bolt. You pull the wood, twist 90 deg and lock two cabinet doors.
Posted:
Tue Apr 26, 2005 10:19 am
by fornesto
I am a big fan of sliding cabinet doors instead of swing-open doors. First, they are easier to build, second, they don't require that you clear off your countertop to open them. third, they can be locked very simply by drilling a hole through the overlapped part and inserting any type of rod. That's what I did with my first galley. The second one will be a bit different
Posted:
Tue Apr 26, 2005 2:02 pm
by bdosborn
I'm using window sash locks. About the cheapest hardware going.
Posted:
Tue Apr 26, 2005 10:19 pm
by Denzagrad
bdosborn wrote:I'm using window sash locks. About the cheapest hardware going.
I use wooden turnbuckles (sp"). Cost was scrap wood.
Posted:
Tue Apr 26, 2005 10:38 pm
by Guest
Guy turned me on to those rare earth magnets.
I know this sounds crazy, but they won't even be touching one another, they'll be recessed and hidden under the wood. There won't even be any sign of a latch. When I get close to that point... I'll order them and do a test just to see how strong the holding power is. (A little verbage on the magnet's website warned not to play with them because of the severe pinch they can cause, if you inadvertainly get your finger in between two of them)
Magnets
Posted:
Tue Apr 26, 2005 10:49 pm
by OkieSailor
What was the site you are looking at for the rare earth magnets?
Posted:
Tue Apr 26, 2005 10:56 pm
by Guest
Posted:
Wed Apr 27, 2005 11:50 am
by denverd0n
Those magnets are SUPER strong! If you've ever taken apart a computer disk drive, this is the type of magnet they use.
I hadn't thought of that, but these magnets would be great for keeping sliding doors closed, yet easy to open. Drill a little recess, use a little epoxy to keep the magnet in place, voila!
Posted:
Wed Apr 27, 2005 12:57 pm
by mexican tear
Just ordered some.
kai
Posted:
Wed Apr 27, 2005 1:17 pm
by bdosborn
Denzagrad wrote:I use wooden turnbuckles (sp"). Cost was scrap wood.
I almost did that but I was afraid that the turnbuckle would create a wear spot on the cabint face over time. Have you had any trouble like that or was I overthinking the problem?
Posted:
Wed Apr 27, 2005 1:21 pm
by catrinka
I like the idea of window sash locks but I've been having problems locating them. Where are you guys finding them?
Posted:
Wed Apr 27, 2005 1:23 pm
by bdosborn
catrinka wrote:I like the idea of window sash locks but I've been having problems locating them. Where are you guys finding them?
Lowes or Home Depot around here.
Posted:
Wed Apr 27, 2005 1:43 pm
by toypusher
You should be able to get them from almost any hardware store.
Kerry
Posted:
Wed Apr 27, 2005 3:28 pm
by angib
bdosborn wrote:I almost did that but I was afraid that the turnbuckle would create a wear spot on the cabint face over time.
So you cut out some nice little crescents of brass and fix them in place as wear strips - as found in my 1904 house! Very pretty.
Actually you cut out circles of brass and then cut them into a big bit and a small bit - the big bit is the wear strip on the fixed side and the little bit goes on the door or drawer. Making them is the ideal activity while waiting for some paint to dry.
Andrew
