Bottom coating idea.....?
Postby swaman » Sun Jul 26, 2009 6:08 am
Hi All!
I was just wondering what you all thought of the idea of using a truck bed liner, such as "RHINO LINER" as a protective bottom coating instead of the most common roof coating? If it's as good as I've heard, seems like an inpenetrable covering that would never need touching up or re-coating. :thinking:
Thoughts?
Frank
swaman
Postby BrwBier » Sun Jul 26, 2009 7:06 am
Most bed liner type products only work well on a almost surgically clean painted surface. They are also more expensive that necessary for what you want to achive. I used auto rubberized undercoating in spray cans. I think it did a good job and is easy to touch up IF necessary, but it hasn't been yet. I did it as the last step and I like how it sealed everything.
Brwbier
BrwBier
Images: 100
Postby bbarry » Sun Jul 26, 2009 7:35 am
I agree that, while it's a good product, Rhino Liner is entirely too expensive for this use. I also used spray undercoating (Mar-Hyde). It took 5 cans to get it to my liking.
The stinky black goop is even cheaper and just as effective.
Just my two cents,
Brad
Brad
Jack of all trades, master of none.
Kampster build thread
bbarry
Images: 159
RHINO Liner
Postby swaman » Sun Jul 26, 2009 8:01 am
Thanks Guys!
I guess I'll stick to proven basic elements and spend what I save on more toys!
:applause:
Frank
swaman
Postby Steve_Cox » Sun Jul 26, 2009 8:13 am
My trailers have "stinky black goop" that hasn't needed any touch-ups for 3 years I would think your choice in bottom coatings is dependent on what type of towing you intend to do. Even bed liner might not be tough enough to skid the trailer over downed trees on a trail. Some people have been successful using just paint. One thing you won't want to do is like some RV manufacturers and put a sheet of plastic under it. plastic sheeting can and will hold moisture in between the floor and plastic causing the floor to eventually rot.
Steve_Cox
Images: 196
Re: RHINO Liner
Postby bbarry » Sun Jul 26, 2009 8:19 am
swaman wrote:spend what I save on more toys!
AMEN! Preach it brother! :applause: :applause:
Brad
bbarry
Images: 159
Postby BrwBier » Sun Jul 26, 2009 10:13 am
So, in teardrops & TTT does the TTT stand for toys, tools and trips? :lol:
BrwBier
Images: 100
Bottom coating...
Postby swaman » Sun Jul 26, 2009 11:18 am
I have to be reminded to KISS myself every now and again.
"Keep it simple, STUPID!" :rofl:
swaman
Postby kennyrayandersen » Tue Jul 28, 2009 4:06 am
truckbed liner is cool and all, but they ain't giving it away
kennyrayandersen
Images: 38
