Trailer frame modifications.
If I use the Tractor Supply trailer I just picked up (see General Discussion) just as it is I'm going to end up with the following:
4x10 Trailer For Two on the 4x8 frame with 6" over on the front and 18" overhang on the rear. This is going to put the axle center at 66" from the front of the body and 54" from the rear of the body. Should the axle assembly be more towards the rear to prevent swaying? How important is axle location as compared to weight distribution? It may well be easier to extend the frame bed forward and lengthen the tongue. I have a drawing but having trouble scanning it. Will keep working on it and try to load it here. Thanks all... Dave
