Square Tubing
Square Tubing
Postby Gary Sutherland » Fri Aug 07, 2009 3:50 am
Reading the thread about welding sheet metal to tubing made me wonder....
Those of you who build your frame with square tube, how do you bend it? Do you own a tubing bender of some sort, do you send it out, or have you found a good way of bending it with whatever tools you happen to have?
If you send it out, about what does it cost?
I doubt I'll ever have a real shop to build in, but it's a nice dream :thinking: .
Gary
Gary Sutherland
Postby Billy Onions » Fri Aug 07, 2009 7:38 am
I used an Italian BPR Section bender
Spec here
http://www.eaglebendingmachines.com/new ... RAY33.html
I marked the profice on a piece of 8 x 4 sheet and rolled one side at a time.
If you were to get a local fabricator to do this for you, to give you an idea iof the cost, it probably took me 2 hours to set up the machine, mark the profile and roll both sides.
That said my machine has a 1.1/2" capacity. When I have rolled 3/4" section I have tacked the ends and a few points inbetween to ensure an identical radius on each piece. So If you wanted to use 3/4" for your build or your local shop had a the ability to roll 2" section that he should be able to do it quicker.
Rolling Home
the gog blog
http://ukteardrops.blog.com/
Billy Onions
Images: 19
Postby emiller » Fri Aug 07, 2009 12:58 pm
I bought a large radius bender this one http://www.tuberoller.com/products/Handtubingbender.htm
If you live near me I'll bend your metal.
emiller
Images: 157
Postby chorizon » Fri Aug 07, 2009 5:00 pm
Someone here had a pretty ingenious/frugal way of bending tubing.
Searching...
Scan complete...
chgrsteve67 wrote:For some of the smaller pieces I made a sqare tubing bender out of a old truck brake pad and a 6 foot piece of pipe. A propane torch to heat up the tubing makes it more plyable.
For the big pieces I used two 1\2 inch sheets of plywood screwed together, cut out to the shape of the trailier, I made a lever that could be positioned in several locations that I used to pull the heated pipe around the template. I made several ancors so after its pulled around the template I could keep the tubing in place and then spray it with water. THis hardens the steel so it keeps its shape and puts out the burning plywood.
I thought about taking pictures of the process but I figured people would laugh.
http://www.tnttt.com/viewtopic.php?t=22600&start=15
Seems like a great idea, I don't know about hardening low-carbon steel and all, but his pics show the results, and they are excellent! :thumbsup:
chorizon
Images: 94
Postby mechmagcn » Fri Aug 07, 2009 8:53 pm
For the front radius on my tear, I "rolled" the tubing around a 48" tractor turf tire :o and for the smaller radius at the rear, I "rolled" it around a 36" truck tire :lol: Using this method, sometimes the tubing wants to twist, but a large cresent wrench prevents this.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby kennyrayandersen » Sat Aug 08, 2009 7:53 am
mechmagcn wrote:For the front radius on my tear, I "rolled" the tubing around a 48" tractor turf tire :o and for the smaller radius at the rear, I "rolled" it around a 36" truck tire :lol: Using this method, sometimes the tubing wants to twist, but a large cresent wrench prevents this.
Git er done! :lol: :lol:
kennyrayandersen
Images: 38
Users browsing this forum: Google [Bot] and 4 guests
