Page 1 of 1
Question for Woody builders
PostPosted: Sat Aug 08, 2009 11:11 am
by David S
Do you guys put any kind of bevel on horizantal wood trim and do you use full 3/4" or 1/2"? Never seen a live woody up close most I've seen around here are aluminum clad.
Thanks In advance,
Dave.
PostPosted: Sat Aug 08, 2009 11:43 am
by doug hodder
When building a woody, I resaw my trim down to 3/8" from 3/4" and plane it, but you can make it as thick and as wide as you want. The edges should be eased like a roundover so that whatever finish you apply, it will bond well. A sharp or hard edge over time will cause the finish to fail at that point, whether you are using epoxy or not. It should also be finished on the back side prior to install. Other opinions may vary, just what I've experienced. Doug
PostPosted: Sat Aug 08, 2009 11:53 am
by len19070
On my SlumberCoach I used 5/4 Cedar for my raised slats split to about 9/16"
But then on my "Pac-Man" I laid another complete sheet of 1/2" over the side profile and just cut out the openings.
Happy Trails
Len
PostPosted: Sat Aug 08, 2009 12:09 pm
by Juneaudave
Dave...I think they are all different. This one has side trim inlaid with the outside edge rounded over with a 1 1/2 bit. The battens running over the top are applied 1/4 inch thick steamed ash with a 1/4" round-over...
PostPosted: Sat Aug 08, 2009 12:31 pm
by 48Rob
I used 3/4, and put a bevel on it.
Rob
<img src="http://img.photobucket.com/albums/v284/1948rob/cabin%20car%20hatch%20hinge/IMGP9875.jpg?t=1249752519">
PostPosted: Sat Aug 08, 2009 1:40 pm
by Steve_Cox
Another with 3/4" width with a radius edge. This trim was built up from several pieces laminated together.
PostPosted: Sat Aug 08, 2009 7:50 pm
by boomboomtulum
I bought 3/4 maple and planed it to 5/8. With a 1/4 round over.
Dave
PostPosted: Sat Aug 08, 2009 8:57 pm
by Sam I am
I went with cheap and simple because that's how I am! I made trim from cheapie 1/4" underlayment ply. I varnished both sides of it, and especially the edges, then attached it to the walls with short wood screws with caulk in every screw hole. then I put iron-on 3/4" wide edge banding on the edges and varnished that. It has held up well for three seasons, including towing and camping in some heavy rain.
PostPosted: Sat Aug 08, 2009 9:29 pm
by Sparksalot
I cheated and used aluminium.
