by scotchale » Sun Aug 16, 2009 5:47 pm
I recently adapted a Q200 grill to connect to my outside, external RV propane outlet, which is regulated from the main tanks of the RV. The grill normally runs on the portable camp-canisters, and is regulated with the built in regulator on the Q200 grill.
However, with the lower regulated output of the RV supply, 1 to 3psi (range), the pressure is too low for the grill. It will still light up and heat, but not realistically enough output to cook anything. I wasn't sure how well this would work until I tried it out, and those were the results.
For now, I connect the Q200 with an adaptor hose I had made to fit a propane tank supply directly, not through the RV regulator, then the higher pressure of the tank is then regulated by the internal Q200 regulator, works fine, and I can do without the little cartridges, which was the objective.
Bryan
