I'm still in the planning stage of my first TD (Benroy), and need some help with trying to fit in an AC. I've decided to put it in the back on the floor, and made as many trims as I could to get room for it. I decided to go with a Colman queen size air bed, it is 78" long, not the standard 80", and I gained another 3/4" by putting in the front spars short side up, and a slight modification of plans on the way the rear is cut out for the hatch seals, and I have just 15.5 inches (If I skin the inside of the hatch) of room for an AC that is 14.75" deep. How do I need to vent it? I planned on putting it close to the driver side wall, and putting a vent in the wall to the outside. I know I'll need to put a hole in the floor for the water to run out, but not sure how this is best done. All these mods are not just my little AC, I also want to fit a Colman Power Chill cooler (15" deep) in the gally as well. I plan on mounting it chest style on a pull out platform. Also, I thought up a little trick, mounting a 19" LCD TV to an inside cabinet wall, giving a cabinet in the gally deep enough for a microwave. Has anybody bolted an LCD TV directly to plywood like this before?
Any help would be appriciated.
