Deryk the Pirate wrote:Hello folks, Ive been readin through the forums, and Im guessing people are using an exterior grade (or marine grade) plywood? Ive seen some people are tarring the underside, what other treatments are availible?
...marine grade is overkill...better encapsulation/sealing will do ya better...tarring the underside is the cheapest way to seal but any sealing is OK...paint. urethane, epoxy, undercoating, bedliner are all OK...
For the roof, Ive seen mention about CPES, epoxy, epoxy and fiberglass cloth, spar varnish, Aluminum, I was wondering if http://www.nonslipcoating.com/
would work? I was thinking about painting it with the smooth version, since it says it seals and protects.
...if you truly want it sealed up to protect your investment, some sort of solid membrane is best...AL, epoxy with a topside urethane paint or epoxy with cloth, FRP(Filon) or EPDM rubber roofing are your best bets...bedliner has been used both successfully and also with disastrous results...CPES is GREAT STUFF but personally, I would just opt for regular epoxy and be done with it
thanks
deryk
jay wrote:. . . sigh . . .
every time i think it's safe to come back . . .
Deryk the Pirate
For the roof, Ive seen mention about CPES, epoxy, epoxy and fiberglass cloth, spar varnish, Aluminum, I was wondering if "nonslipcoating"
teardrop_focus wrote: People have been discussing the use of soft vinyl as used for automobile tops or boat upholstery in this thread:
How about vinyl or naugahyde to cover teardrop?
After a season or two outside, the vinyl polymers begin to crystallize and lose their flexibility - then the cracking begins - Now back to the options again...
Can't say I see many landau or vinyl topped cars very often anymore. Either way, those had steel under them so leakage was not an issue. With the trailer, vinyl will likely have wood under it, so even a small leak over time will be a problem (and maybe not apparent til it is a big problem).
As the owner of a convertible, even those tops also do wear out after time and that material is pretty spendy.
