anybody trying abs yet
Postby jesse c » Sun Sep 06, 2009 8:25 am
at work we mold abs plastic sheet over plaster molds and sometimes vacuform over molds.I was thinking with a bit (a lot?) of pre work you could make some reuseable molds to crank out any number of duplicate parts,and if your design was symetrical you would only have to make half the molds since your right rear would be the same as left front,etc..and pieces could be abs glued together.You could even make abs ribs for stifening and attatching interior panels
I work in the theater industry and build lots of cool stuff out of 1/8"ply sometimes bending and laminating plies that are extremely strong and lightweight to carry rapidly offstage during quick set changes. 1/8" ply is usually much higher quality than 1/4" luan and is almost as strong due to that fact
Sorry,just sitting here dreaming of building a mini trailer and thinking with a keyboard in front of me
jesse c
Postby Greg M » Sun Sep 06, 2009 3:11 pm
Don't apologize. Crazy ideas are what we're about around here :?
-Greg
Greg M
*Geek Extraordinaire
Images: 85
Re: anybody trying abs yet
Postby kennyrayandersen » Wed Sep 09, 2009 7:59 pm
jesse c wrote:at work we mold abs plastic sheet over plaster molds and sometimes vacuform over molds.I was thinking with a bit (a lot?) of pre work you could make some reuseable molds to crank out any number of duplicate parts,and if your design was symetrical you would only have to make half the molds since your right rear would be the same as left front,etc..and pieces could be abs glued together.You could even make abs ribs for stifening and attatching interior panels
In a word: Tooling costs
Also, the ABS, would have to be pretty thick to be ‘structural’, or it would have to be bonded on to something to make it structural.
kennyrayandersen
Images: 38
Postby teardrop_focus » Wed Sep 09, 2009 8:14 pm
jesse c
Personally, I don't like the idea of sleeping in a plastic teardrop. Now I don't know the differences between abs and pvc plastics, but... I'd rather build out of and sleep within a wood structure*.
And, like Greg just said, keep the ideas coming! That's what this place is allllllll about.
:pipe: :dancing
*Although with the epoxies used to seal wood against the elements, the "exterior" glues used to laminate the birch ply I intend to use (slightly less potential hazard than "interior" glues) and the spar varnish used to seal and color the interior birch, there'll be plenty of potentially hazardous fumageses... at least until most of it cures. Who knows...
teardrop_focus
Images: 127
Postby Ageless » Wed Sep 09, 2009 8:26 pm
Not a bad idea; but do you know what is involved in making a mold? You create a 'master' and it has to be almost perfect; then you make the mold off the master. We are talking many hours, 100+ for a 12 x 36 inch part.
For a single application; this is a waste of labor. If you plan to produce 100 units; you might get to a break-even point.
Ageless
