Page 1 of 1
Advice on how to seal plywood roof seams/waterproofing
Posted:
Wed Sep 09, 2009 2:27 pm
by Dick
Added the second layer of 1/8" baltic plywood to the roof today - thanks to all for the tips on using PL Premium.
I'm getting ready to do an application of CPES from the Rot Dr in next day or so and then filling any holes with something.
Question - what's the best way to go about sealing the plywood joints on top of the t and filling any nail/screw holes?
Thanks for all your help - couldn't build the t without this website.
Posted:
Wed Sep 09, 2009 2:29 pm
by planovet
I used an epoxy filler, also by Rot Doctor. I applied 2 coats of CPES to the ply (before I put it on the roof), Stapled/epoxied the ply down, then filled the holes with epoxy filler, sanded and then put on one last coat of CPES. Overkill? Maybe but it isn't going to rot
http://www.rotdoctor.com/products/fillit.html
Posted:
Wed Sep 09, 2009 3:09 pm
by Steve_Cox
1st choice for me is what Mark said
Posted:
Wed Sep 09, 2009 3:12 pm
by Mary K
Epoxy epoxy epoxy epoxy!
Wished I'd done it!!
Posted:
Wed Sep 09, 2009 3:52 pm
by aggie79
On the roadside of my floor, I did 3 coats of CPES and Bondo for filler (yes I know it is polyester resin based) to be followed by undercoating (hopefully this weekend.) And yes, this is overkill.
Posted:
Wed Sep 09, 2009 7:13 pm
by kennyrayandersen
You could also put a strip of fiberglass tape across any seems to and strength and keep it from cracking. You may not need it if you are finishing with aluminum and it is well sealed, but it would guarantee that you have a solid seal between sheet splices.
overkill, isn't such a bad word, as long as it doesn’t add too much weight!
thanks for all the advice
Posted:
Wed Sep 09, 2009 10:55 pm
by Dick
Looks like epoxy is the way to go - thanks for taking the time to send info/pics.
